Gotta say, having seen both the Z06 and R35 in the flesh i'd be more inclined to take the Z06 as a track car. Sounds absolutely amazing and looks to be much more of a drivers car, the R35 has too much electronics and hi-tech gizmo's to really be able to have fun in it.
i race against a Z06 and they are really quick and heaven forbid very reliable as well. This thing has always finished every race its been in.
Ohh god just found out there a bloody dogde viper entered in the series as well now......
The bloke loves checking what gear he's in.
gee.. dont you love the keyboard worriors that enjoy perusing you tube? People that seem to know soooooo much abour cars and racing that have never stepped foot out on a race track..
hey, that is a bit weird, i remember getting lost with mine also, guess its a 6 speed thing. i remember i just used to skip gears on downshift, get confused and leave it in neutral. lol.
It's a V8 thing, sometimes I have to check mine to see what gear i'm in too :(
I was fine with my 6 speed in my old car, but then drove a mates with a short shifter and absolutely sucked at it and jumped gears!!!
didnt like the short shifter on them!
For me it was more of a not knowing what gear you're in, rather than missing gears. Not used to the torque of a V8! I'll still do it sometimes, 3rd and 4th can seem pretty much the same sometimes.
I've got a Ripshifter in mine and it's miles better than the stock throw. Stock is way too long... hell, even the ripshifter is still too long :(
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
