ok so heres a bit of info
Just picked em up
grabbed some purple as well
brad had to take some meat from the turbine housings to match to the new manifolds
as you can see below a fair bit had to go
installing the new studs
dumps joined
manifolds attached
nice pair
Hmm i can see why there is no point in putting manifolds with small low mounts.. happy sticking with stockers now!
The size difference from that rear housing to the manifold gasket is huge!!!
very nice i have just started to do the same thing with my car atm going the same turbos to :P
any tips for taking them off?
run into any problems fitting them?
i have heard you have to do some mods to the oil return holes?
were did you get your gaskits from?
did you buy a kit?
or just get them from nissan?
can not wait to get mine on there and tuned!!!! :blink:
any tips for taking them off? - not really just keep your cool lol
run into any problems fitting them? - just doing up the bolts for the manifold when reinstalling
i have heard you have to do some mods to the oil return holes? - yes just drill the bolt holes a bit bigger to match the holes on the turbo thats what i did
were did you get your gaskits from? - kudos motorsports trader on here tell him jason sent you
did you buy a kit? - from kudos motorsports
or just get them from nissan? - lol no
Looks the goods mate :laugh: Im very interested to see what numbers you pull! I had a set of these put on my car 2 weeks ago and made 258rwkw on 14 psi and 316rwkw on 18psi on a Mainline dyno, but i used match ported standard manifolds and HKS split dumps and D-Jectro. Good luck and i hope all goes well :)
Yep I got the tomeii stainless manifolds and port matched to the turbine, it's worth doing it on the standard manifolds too as it's a major restriction as stock. You get a much better spool response. Ported like in this pic. Gonna have to do a side by side soon Jase! Here's also the CES race dumps for those interested.....
Edited by doo doo
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
