Given a fairly optimal tune on pump gas, what + does a tune for C16 give - as a percentage on base tune?
assume twins or a single, doesn't really matter, any real world experiences? I know from a search
that dirtgarage dyno'd at 400 something on pump @ 28psi and 460 something on race @ 34psi.
So that would be roughly a 15% improvement. It wasn't clear whether that was two optimal maps
or just gained from upping the boost, though..
I'd also love to know if that is 15% all through the rev range, or just at the top end..
Since power-fc is so common, with its single map, perhaps there aren't many documented examples?
but maybe cars with Motecs, Vipecs know the answer..
https://www.sau.com.au/forums/topic/253466-pump-vs-race-or-c16/
Every car, every setup is different.
There is no set improvement. Some people see massive gains due to restrictions and also the flip side of better flow
Some people less because they can already run good timing numbers
Nothing set IMO. Take it on its own merit.
thanks,
but that can be the answer to almost every question here that has the word "power" in it.
Was hoping for some real world examples if there are no rules, or even rules of thumb..
nobody (with time to post) runs two maps and two fuels?
the combustion characteristics of the race fuels are obviously quite different ( in a good way) and therefore not only does this effect everything in a tune , from cam timing to AFR but, also if you intend running a car on race gas then you can do allot to the way the engine is built for optimisation or the reverse if you are running on a fuel the build was not intended for.
Hence the comments along the line of 'how long is a peice of string'.
If you wanted a guide there really is only one for motors of the same type , spec and build assuming the same tune. Sounds pretty useless doesn't it.
However, as a rule 'race fuel' will always offer some benificial gains over BP regular etc.
Some street based cars use it due to it's nicer burn characteristics and soley run it to protect the motor in races or the occasional motorsport event. It is not uncommon for there to be little or no power gain chased by these situations. The fuel is consistantly good unlike pump fuel experiences and offers the margin of safety for extreeme events.
My mates and I used to fuel up with Av-gas for a trip to the drags (prior to my skyline days). We found it better for the day at the drags for things like vapour lock on a hot day and also to help things like when jetting for temp changes during the meet it was easier to get it right. Although the gear we play with is high tech the race fuels offer a more forgiving margin.
Hope that helps. :)
Edited by rev210
Hope that helps. :)
It helps a bit.
But I was thinking more along the lines of feedback from someone who runs or did run an ECU with two maps and
(obviously) the same engine. What did they dyno on the pump gas map and what did they dyno on the C16 map.
From reading experiences outside skyline/rb land, but still from forced induction motors, going from pump to
C16 allowed quite a thumping increase in torque simply obtained by advancing the timing and increasing the boost
and running leaner.. three things some ECUs can do all at once without any change to engine setup.
But it wasn't clear from searching whether there are RB26 engines have reported the same result.
Another way of looking at the question: if australian servos switched to japanese pump gas - which isn't anything
like C16 - you guys would be off to the tuner to get remapped, yes?
I wonder what % gain would be typical. 1%? 5%? 10%?
^^ much better words than i put in :)
I made over 100rwkw more with just 6psi when i used 104 vs pulp, but as i said, i had a restriction so the better fuel negated that massively and an extra +8 degree of global timing. BUt not everyone will see such gains and so on
The better fuel may have negated the restriction more than you think if the restriction was in the exhaust/exhaust housing.
I knew what you meant - maybe we mean the same thing ;)
I was just saying that the tune-up on race fuel with the extra timing would likely have relieved some of the back-pressure issues you had.
Like I said, we're probably saying the same thing...
It was 270rwkw and a choked 270rwkw at that, and this was on 17psi... bumped to 24 (ok 7psi, my brain isnt good with math) :O
This was all on the big 600hp GT30, not the 500/550 littler ones so there was other issues with comp surge and so on to deal with.
On the pulp tune anymore and it would get agro with detonation and so on, there were a few factors involved/fixed/relieved other than just a fuel/timing change as Adrian has said in a better way than i did :)
The figure sounds about right for what a 600hp turbo on fuel should do seeing as though the GT35's on PULP get similar numbers
So ye Adrian - we are thinking the same thing :D
It all depends on the efficiency of the engine/set-up...the more efficient the engine the less the gain as it burns the fuel better and consequently transfer's its energy into power better. For example my old set-up (the example you gave) used to see over 50-60awkw gain (best back to back run we did was 70awkw)...now its only about 20-30awkw. A stock or near stock set-up may see 85-95awkw gain (Ash's car is a perfect example of ths).
hope these real world example's are of help.
Edited by DiRTgarage
that is interesting.. thanks. So what mod do you most attribute the reduced gap to, for your particular engine evolution?
I assume both outputs went up, but the pulp went up more (thus closing the gap)?
I take it your only talking a topend power figure when your refering to engine efficency. Better fuels should always make more horsepower and if they dont then its time to make the engine more dynamic.
the head
Well midrange is also massively improved with the added timing and so on, boost sooner etc
the difference was night/day with my car and not just because of the 100kw... without the +8 timing it was still amazing with just the extra boost... the timing just made it silly :P
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
