Here's a quick shot of my screen install in the 33... the paint job on the dash fascia isn't finished yet (still got one more coat of the silver and then a couple of coats of clear), but you get the idea.
Got music/video/pics, FM radio (though I've gotta work out a better antenna... the reception is pretty poor at the moment), GPS (USB GPS dongle - $50 eBay - and FreeDrive software), all running through the FreeICE frontend (for the moment - as a software developer I'm hoping ot oneday get around to building my own from scratch... I've used Centrafuse, RoadRunner, FrodoPlayer, and a couple of others from http://www.mp3car.com/... personally I find FreeICE does the job for me for the moment.
Edited by Samon
  • Replies 95
Posted Images
Just wondering if anyone has installed a webcam in their car?
I'm planning to install one facing forward (Front windshield) and the other facing backward (rear windshield). Anyone recommend any brands/models?
I require the camersa to be fairly heat proof as they will be exposed to the sun on the dashboard and rear parcel shelf.
I ended up buying a USB GPS unit for my car PC from eBay. I too need to find software, the only one that seems to suit my needs is co-pilot live. http://www.travroute.com.au/index.php?opti...33&Itemid=1
Wondering if anyone out there knows any alternatives to co-pilot.
I checked the site out, so far as i can see the data for maps looks pretty old. 2005? Also looks like it may only have maps for the US which seems to be a consistant problem from the apps i've looked into.
i have a Mini pc i had set up orgionaly to use for a media center at home sitting here, and i have been toying with the idea of making it into a car pc, my only concern is the start up times for the front ends... i think it would annoy me alot to have to sit and wait for the pc to start up all the time....
so i dont think it is really for me, but if someone is interested in the pc i have here... i will happily sell it off.
M330 case
Zotac ionatx-a-u (duel core 1.6ghz, 9400gt video card)
4GB RAM
320GB HDD
board has built in wifi, hdmi optical and spdif auidio outs.... if any one is intersted in it pm me XD (need cash to pay for some wheels hahaha)
http://i272.photobucket.com/albums/jj164/cbruss/IMG_0037.jpg
i had a laptop-based carpc at one stage, for about a year.
i had startup and turnoff times down to under 5 seconds, from suspend (battery in laptop enables this, as long as i turn it on once every few days it would resume with no problems).
running a stripped down XP
and roadrunner frontend
was pretty awesome.
was pretty awesome.
not bad at all.... tempted to grab my old laptop and give this a burl :blink:, did you just run it through an inverter?
not bad at all.... tempted to grab my old laptop and give this a burl :D , did you just run it through an inverter?
You don't need to bother with an inverter, as you will be running DC-to-DC. You can buy a universal laptop ciggie lighter adaptor on ebay for under 20 bucks, they work quite well, you can also hard wire into your car if your handy with a soldering iron and know which circuits to tap into :)
hey guys been rading this thread, and the carpc seems like a great alternative to a new headunit. My current cd player is very basic and OLD, doesn't play mp3's so im constantly changing the cd, quite a pain, and its on its way out, always freezing, or skipping tracks.
I've got a laptop that i currently only use for media/tv/dvd/itunes. it all sounds so complicated from what i read. but would there be a way of buying a touchscreen to mount into the dash and then having a cable running to the back seat area where i can have it connect to the laptop and run it that way? so i can disconnect if i need to remove the laptop and bring it home. Or is it more complicated than that. im keen on setting up the GPS too for those summer road trips! would the sound quality be awful since its comming from the laptop? the current set up is just the stock standard from what i can tell.
any ideas would be great, and what sort of price range would i been looking at, if i wanted to use my current laptop?
Personally I'd try to find a docking station/port replicator... that way you can leave all the cabling setup correctly and just unclip the laptop and take it out. The other advantage of this is that you can setup different profiles in windows for 'docked' and 'undocked'...
Maybe check eBay?
And the audio quality from the onboard soundcard is pretty pathetic... an external sound card eliminates a lot of the interference.
I'd expect around $400 for a decent double-DIN screen, about $70 for a good USB GPS receiver, around the $150 mark for a decent USB sound card, allow at least $100 for random cables, etc...
Oh and if you don't already have an amp setup for your speakers you're gonna need (at least) one - the power output of a lappy or even USB sound card is only headphone level, you need to feed that to your amp(s).
Maybe check eBay?
Docking station - Definately a top idea :P
In regards to the sound card it can depend on the laptop. I find many of the HP branded laptops/tablets have pretty clear and low distortion sound - but I must stress not all. Might save you a few bucks and extra connections - just an idea.
Maybe... I've got two HPs, a Compaq, an Acer and a Toshiba and while the audio quality from one of the HPs and the Toshiba is actually not that bad, once hooked up to the DC->DC charger with the engine running there is a noticable amount of audio interference... not TERRIBLE like my Compaq, but when I built this system I wasn't going for just 'good enough'... with the external audio system there's NO interference and the audio quality is in a totally different league...
I guess for me, if it couldn't at least MATCH the capabilities/quality of a mid-high end headunit setup, it wasn't worth it... I mean for around the $1000 mark I sepnt setting up my system I could have picked up a fairly decent headunit (probably without GPS, admittedly) which would have had most of the features and a decent audio quality... althought having the PC in there is certainly much cooler and certainly wins plenty of geek points :P
I guess for me, if it couldn't at least MATCH the capabilities/quality of a mid-high end headunit setup, it wasn't worth it... I mean for around the $1000 mark I sepnt setting up my system I could have picked up a fairly decent headunit (probably without GPS, admittedly) which would have had most of the features and a decent audio quality... althought having the PC in there is certainly much cooler and certainly wins plenty of geek points :(
Out of curiosity are you using a soundblster Extigy/Audigy external?
Im running a dell c640 latitude $100 laptop in my car
wires up to my ecu and also consult port
not running music thru it, simply for tune checks etc
got a usb/cig.lighter $20 unit that runs and plays my mp3 usb on 90.9fm over the radio
Audigy2 NX... though If I were doing it again, it'd probably try to find one of the older Extigy ones... mainly just because they run on plain 12V (audigy runs on 5V, but unfortunately draws too much to be self powered from the USB port...) which is easy to come by in a car, and don't even need a voltage regulator! A lot of the guys on mp3car.com just wire them straight into the 12V from the car with no problems. of course if you're going for a mini-atx carPC instead of a converted laptop like I did, then you could easily run the 5V line from one of the molex power connectors from the power supply, but for me that wasn't an option.
I struggled finding "backups" of the software on the internet - especially for Australia.
I bit the bullet and bought some Garmin laptop software 2010 version from eBay and connected it to my USB GPS dongle.
It was a fiddly setup because the GPS dongle I used was not a Garmin product. But I got it all working eventually.
Personally I think it is money well spent.
Reasons:
- Maps load much faster.
- GPS seems more accurate (could be related to the USB dongle)
- Smoother interface.
- GPS seems to lock on faster (could be related to the USB dongle)
- Zoom in/out function is less fiddly compared to a "conventional" GPS.
- Has handwriting recognition for entering addresses (if you use a stylus).
- When playing music the software automatically reduces the music volume by around 25%, when giving directions (some people may not like this function) - when not giving direction music plays as normal.
- Basically its like a portable GPS on steroids.
Has anyone done a headunit relocation in a 33 for carpc? I've got a lilliput screen in a double din mount ready to go in but also want to keep a normal headunit, I was considering replacing the lighter/ashtray with it but there seems to be a lot of plastic behind there that supports mounts and the frame further up.
Theres a centrafuse 3 edition with nav if anyone is interested in a commercial solution...
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
