For sale here is an excellent, quality 5 speed manual R34 GT-T Skyline. It has been very well looked after with regular services (3000 - 5000 K's) using quality oils. The car runs extremely well, and my mechanic says it is one of the cleanest Skylines they have ever seen (Dynamic Mechanix, Rockhampton, Ph. 07 49272112).
Why pay $20000 for an R34 with little mods when you can save thousands by buying an already modified car that is in better condition than most you will see.
My modifications include;
- Hi-Flowed turbo by GCG still under warranty
- Blitz front mount intercooler (mounted properly with a sports radiator fan so the cops will leave you alone)
- Blitz turbo back exhaust
- Nismo oil cooler
- APEXi Power FC
- Blitz ID3 electronic boost controller
- Blitz turbo timer
- Black mags with Bridgestone Potenza Adrenaline RE001 tyres for awesome grip, still with most of their tread
- Turbosmart blow off valve
- Bilstein coil-overs
- New brake pads and spark plugs
- Dark window tint
- Clarion CD head unit
- Inverter in the boot so you can hook up a tv and dvd (I have both and I will include them in the sale if you like)
This car recently received QLD Transport approval so it is a hassle free car, the cops will leave you alone.
Anyone who has seen me driving this car around knows that it has not been thrashed, and that it is well cared for.
I will be sad to see it go, but am purchasing a house so it's time to downgrade.
I live in Emerald but can easily drive to Rockhampton, Mackay, Brisbane etc. for any genuine buyers.
Please feel free to call me with any questions.
Matt, 0419668773
Thanks mate, it's a nice car isn't it.
I have had a lot of interest and have had people try to finance the purchase of this car but unfortunately were turned down. I don't think it will last long at this price and in such good condition so get in quick.
Due to my remote location I am happy to take the costs of flight to Rockhampton to view the car off the purchase price (up to $500) if you buy it. If you want to fly up to see the car I can meet you in Rockhampton, but I will only take the flight costs off the price of the car if you buy it. If you don't buy it then you will have to pay for the flights.
I just thought this would help serious buyers get a good look at the car and what great value it is.
Virgin and Jetstar always have cheap flights to Rocky, from as little as $39 from Brisbane.
It made 250hp at the rears with stock injectors and fuel pump. Was starting to run lean. With bigger injectors and fuel pump and higher boost you will make a lot more power. The hi-flowed turbo is rated to 450hp.
Offers!!!
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
