Download "Utorrent"and install it.
Go to a torrent site (you may need to sign up).
I use www.isohunt.com as a torrent search engine. Open the torrent file with Utorrent choose the save location of the file and you are away.
the 'good' way is to purchase and download them through itunes.
otherwise that you can use a torrent search engine like isohunt.com or mininova.com, and download the torrent through a downloader like utorrent or bittorrent. Google it, there is a lot out there..
Does iTunes sell mp3's?
Excuse the ignorance as i thought it was just for fancy people with iPods.
If they do.. Whats the bps rate of them? 320?
Do they have literally everything or just alot?
beware of itunes, some head units refuse to play songs downloaded through itunes due to some reason that i can't remember at this time, but its stated on some of the specifications of certain HU's
remember people, download all you want, but the file must be deleted with 24hrs, its a promotional thing...
so their not mp3's?
I'd go with no, that said, there are other ways to dl music legally, i think its through bigpond you can do it, i don't know if you face the same issue though, never heard of the issue before with bigpond music
http://www.hymn-project.org/
This small program converts protected m4p or m4b audio files to either standard iTunes m4a files or, better again, mp3 files. It claims to convert the files without any loss in quality and the end result sounded pretty good to me.
thats correct slim
you can change it so when you import songs (i.e burn them to the cpu) they are imported as mp3 rather than the other.
But songs you buy from itunes aren't converted for some reason..
    • Messing around with. Twin kit for. Rb30/26
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
