  • Replies 219
Posted Images
count me in boys
been ages since we catch up : )
holy shit i cant beleive he is coming out... i may be there, not sure, as i have to find a driver... only three months left of no license....
JUST TO TEL YOU ALL..I HAVE ONLI JUS RECIVED A MESSAGE FROM THE LAD WHO HAS ORGANISED THIS CRUISE!!THE CRUISE IS THE 7TH EVEN THO THE DRIFT BATTLES R ON! deffo b ther!!!!
Thanks for that Andy.
I'll still be at Drift Battle, so if I can make it so can you!!
That's not a bad idea, you can all cruise to the City West meetpoint and go from there! You can sort that out, I'm going straight to South Street and get there nice and early.
And Benson, if you don't introduce yourself this time, I will have to hunt you down :P
Edited by NA_Goodness
benson u looking for a passenger at all alix wont be able to make this cruise but i still wanna make it let me know dude
or scr34m ill drive :thumbsup:
Yea Dude Im Free for this one so you can steal passenger seat haha fkn alix, tell him to get his act together :D
I'll drive :( I cant believe Teo is coming out either, but Im not complaining! lol
heheheh hello boys. you guys make me sound like a hermit in a shell. my coilpacks are now fixed (i hope) thanks to brendan. sorry for the sunburn on yr back though. hehehe
see you guys there : )
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
