Sorry to anyone I havn't gotten back to need to pull things off and organise pics etc.
Wrecking as the car was needs an inspection etc and I can't justify putting a new motor in and trying to sell the car complete with the market for used cars as it is right now.
  • Replies 44
Like I said before I'll take the front & rear Kansai strut braces if they fit over my high mounts, and I'm in Adelaide.
If you'd prefer to deal locally rather than post, please PM me your contact details.
I might be interested in the Getrag too. Anyway, shoot me your contact details and I'll come around for a yarn.
Nismo arm set consists of Rear camber arms, rear lower control arms, rear traction arms, front upper camber arms. $220 per pair or $800 for the set of 8 pieces.
Interested in varoius parts and I'm in Adelaide please contact Mark : 0429 606 894 because you have not repied to the Pm I sent.
Cheers
Wrecking an R32 GTR, motor has done a bottom end so will be selling all parts seperately.
6 speed manual R34 GTR Getrag ?
HKS 4" High power exhaust pipe $500
TRUST front pipe $200
Greddy GTR aluminium radiator $650
Aragosta Coilovers $1000
NISMO arm set
ATS LSD $800
AW Work mister S2R 9J-17 $1500
TRUST front bumper
Carbon bonnet $750
N1 light and HID 6000 Kelvin $700
R34 GTR Vpec Turbos ?
Exedy triple clutch $1000
R34GT-R aluminium pedal $150
Kansai Front and rear tower bar $300
Shell will also be for sale last of all. All other parts available can send interstate.
Mate
Intereseted in the getrag.
What condition is it?
does it have transfer?
what sort of price are u asking?
thanks
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
