Floor covered - that is in one piece of carpet. I have yet to do the back side between the panels for strength.
forward amplifer gets done in the morning. rear was easier to do.
white neon sticks- these sit under the amplifer and you do not see them. quite bright as well.
underside. the whole lot drops off for servicing from the top
box for amplifer. test fitting everything. 4" fans still to go on the right/left side
struts need gassing. they would not hold the door up originally, now it needs a prop.
Edited by Chris Rogers
Chris, I saw a black Chrysler 300C wagon today with the logo of the shop you recommended to me, is that his own car? Was gonna try and see who was driving it, but got stuck behind slow traffic and couldn't catch up to him... ;)
  • Like 1
  • 3 weeks later...
  • 1 month later...
Sorry if this has been answered elsewhere and it's a noob question but what is the ETC box thingmee in the glovebox?
And is that DVD the stock factory one?
ETC = Electronic Toll Collection
For Japan only
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
