Got my gtr back from my mechanic and i took it for a test drive and there is a hesitation/splutter/missfire at cruise between 2 and 3.5k rpm.
I was told just to reset the ecu so it would go away. I reset the ecu and the problem is still there. Its very annoying.
if i put the foot down it drives normal. weird. Is this normal because the turbos are bigger and the ecu cant read air fuel properly?
mod list
2860 -7's
stock ecu
stock fuel pump
stock dumps
3in exhaust
Edited by R33GOD
You could possibly have a TPS fault, Injector or fuel pump issue, AFM needs a clean. etc. etc.
Clean the AFM's, reset the computer again and make sure all the AFM's are plugged in correctly.
How long did the car sit while the turbos were being fitted?
everything has been unplugged for about 4 weeks.
i sprayed some contact cleaner on the connections and im gonna let it sit til they dry.
just disconnected the batt terminals also. Will connect everything up in 30 mins.
Edited by R33GOD
mod list
2860 -7's
stock ecu
stock fuel pump
stock dumps
3in exhaust
I had the same problem when I got my new GCG - put it down to compressor "surge" so I(I have a Jaycar EIBC) turned the boost down to around 10psi at 2500 -3000 and built upto 16psi from 3500 on - that fixed it.
p.s. you should def think about a vipec (or link) computer
  • 1 month later...
hey mate!
i feel your pain!!
i got some 2860r-5's installed yesterday and its doing the same thing popping, stuttering and missfiring between 2000-3500rpm at half throttle.
its running 13.5psi and the plugs are supposed to be gapped properly.
plus its only making 213rwkw
and it ran really lean at higher boost.
list of mods
R32 GTR
stock internals
stock ecu, fuel pump, injectors
2860r-5's
mines dump pipes
front pipe
high flow cat
3in cat back
pod filters
anyone with any ideas what it could be?
mechanic said it could be the injectors sucking in air?
Brezza
i called Brett at Graham West Workshops and he said it could be the oxygen sensors in the exhaust?
they could be around the wrong way and the car could be adjusting the wrong cylinders for the wrong turbos?
he said he seen this problem before with the car stuttering and that was the problem.
maybe you should try checking for this?
i am gonna get the mechanic to check this, hopefully fingers crossed it is something simple like this and i can start making some real power.
Brezza
u shouldnt worry too much. my tuner told me it can be quite normal on cruise as the mixtures are lean already and by adding bigger turbos ( more breathing) it just leans out abit more on cruise.
mine goes down to about 5 - 10% of the time now. i let my car warm right up before i drive it and i hardly have a hicup.
i have my car on about 12 psi and its fine even if i put the foot down. dosent ping. As for my idle i adjusted the idler set to low and i dont have much idle jump anymore. 900-1000 again.
I also just realised, well a friend pointed it out that i have a huge hks fmic on my car. (knew it wasnt stock but woo hoo HKS!!)Could this be causing some of my hiccups on cruise too?
Also abit off topic but would the HKS cooler i have now make a noticable difference on overall power compared to the stock R cooler?
Edited by R33GOD
Your tuner's a crackhead;
- at cruise the throttle is limiting the air to the same amount that would have been flowing to achieve the same speed with the other turbos
- you wont be on boost at cruise, so those bigger turbos wont be doing anything
- the AFM would read any extra air in that came in and adjust fuel accordingly
- the feedback provided by the o2 sensor is used to further adjust fuel and achive stoic
- mixtures are stoic at cruise, not lean
But i'm in IT so what would I know?
Take your AFM's off and clean them as suggested in post #3
my 32gtr developed the exact same problem. Sometimes on v light throttle or cruising (no boost) everything went dead, then would stutter/hesitate for a second or 2 then feel normal again. Got on the forums, learnt how to do a self diagnostic check on the ecu. Came up with a fault code from the AFM's. Took them both off, pulled the covers of as suggested in the DIY section, all connections/solder were excellent. Noticed the actual 'element' part of the afm in the airflow was covered in oil from accululation over the years.
Removed the flywire @ both ends, sprayed a heap of RP7 to clearn them up the elements and noticed there red :P. Reinstalled AFM's and instantly the throttle response felt a lot more crisp. 4 months later and ive never experienced a hesitation.
Hope this helps
Mike
Hey mate,
i just went to the Mechanic last night and i've discovered its my O2 sensor that it buggered.
being a GTR and having 2 the mechanic unplugged one of them and it got worse, so he plugged it back in and unplugged the other and its running a lot better now. still not 100% still stutters a little at times.
so now i guess i am up for some O2 sensors.
but i think i am gonna need to clean my AFM's, when i put my pods on i noticed that they were a little bit oily and the K&N pannel filter i had in the stock air box was covered in that filter oil, there was even a pool of it in the bottom corner.
the K&N pannel would've filtered good because everything was stuck in it!
like the bloke above said too, the O2 sensor ensures that the mixtures are correct by measuring the exhaust gasses and adjusting fuel to ensure that the mix is correct.
its kinda a pain that i have to change the O2 sensors because of the extra $$$ i gotta spend. but at least i know what the problem is now.
Brezza
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
    • It sounds like you want what the Toyota Landcruisers have for their roof racks. Wanna know what you end up with? Rust holes in the roof, and water everywhere...
    • Discovered today that if I select reverse first and take my foot off the brake, then select drive, the drive indicator light works and so does the tiptronic gear indicator.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Does anyone here have any ideas?   Cheers guys
