Got my gtr back from my mechanic and i took it for a test drive and there is a hesitation/splutter/missfire at cruise between 2 and 3.5k rpm.
I was told just to reset the ecu so it would go away. I reset the ecu and the problem is still there. Its very annoying.
if i put the foot down it drives normal. weird. Is this normal because the turbos are bigger and the ecu cant read air fuel properly?
mod list
2860 -7's
stock ecu
stock fuel pump
stock dumps
3in exhaust
Edited by R33GOD
You could possibly have a TPS fault, Injector or fuel pump issue, AFM needs a clean. etc. etc.
Clean the AFM's, reset the computer again and make sure all the AFM's are plugged in correctly.
How long did the car sit while the turbos were being fitted?
everything has been unplugged for about 4 weeks.
i sprayed some contact cleaner on the connections and im gonna let it sit til they dry.
just disconnected the batt terminals also. Will connect everything up in 30 mins.
Edited by R33GOD
mod list
2860 -7's
stock ecu
stock fuel pump
stock dumps
3in exhaust
I had the same problem when I got my new GCG - put it down to compressor "surge" so I(I have a Jaycar EIBC) turned the boost down to around 10psi at 2500 -3000 and built upto 16psi from 3500 on - that fixed it.
p.s. you should def think about a vipec (or link) computer
  • 1 month later...
hey mate!
i feel your pain!!
i got some 2860r-5's installed yesterday and its doing the same thing popping, stuttering and missfiring between 2000-3500rpm at half throttle.
its running 13.5psi and the plugs are supposed to be gapped properly.
plus its only making 213rwkw
and it ran really lean at higher boost.
list of mods
R32 GTR
stock internals
stock ecu, fuel pump, injectors
2860r-5's
mines dump pipes
front pipe
high flow cat
3in cat back
pod filters
anyone with any ideas what it could be?
mechanic said it could be the injectors sucking in air?
Brezza
i called Brett at Graham West Workshops and he said it could be the oxygen sensors in the exhaust?
they could be around the wrong way and the car could be adjusting the wrong cylinders for the wrong turbos?
he said he seen this problem before with the car stuttering and that was the problem.
maybe you should try checking for this?
i am gonna get the mechanic to check this, hopefully fingers crossed it is something simple like this and i can start making some real power.
Brezza
u shouldnt worry too much. my tuner told me it can be quite normal on cruise as the mixtures are lean already and by adding bigger turbos ( more breathing) it just leans out abit more on cruise.
mine goes down to about 5 - 10% of the time now. i let my car warm right up before i drive it and i hardly have a hicup.
i have my car on about 12 psi and its fine even if i put the foot down. dosent ping. As for my idle i adjusted the idler set to low and i dont have much idle jump anymore. 900-1000 again.
I also just realised, well a friend pointed it out that i have a huge hks fmic on my car. (knew it wasnt stock but woo hoo HKS!!)Could this be causing some of my hiccups on cruise too?
Also abit off topic but would the HKS cooler i have now make a noticable difference on overall power compared to the stock R cooler?
Edited by R33GOD
Your tuner's a crackhead;
- at cruise the throttle is limiting the air to the same amount that would have been flowing to achieve the same speed with the other turbos
- you wont be on boost at cruise, so those bigger turbos wont be doing anything
- the AFM would read any extra air in that came in and adjust fuel accordingly
- the feedback provided by the o2 sensor is used to further adjust fuel and achive stoic
- mixtures are stoic at cruise, not lean
But i'm in IT so what would I know?
Take your AFM's off and clean them as suggested in post #3
my 32gtr developed the exact same problem. Sometimes on v light throttle or cruising (no boost) everything went dead, then would stutter/hesitate for a second or 2 then feel normal again. Got on the forums, learnt how to do a self diagnostic check on the ecu. Came up with a fault code from the AFM's. Took them both off, pulled the covers of as suggested in the DIY section, all connections/solder were excellent. Noticed the actual 'element' part of the afm in the airflow was covered in oil from accululation over the years.
Removed the flywire @ both ends, sprayed a heap of RP7 to clearn them up the elements and noticed there red :P. Reinstalled AFM's and instantly the throttle response felt a lot more crisp. 4 months later and ive never experienced a hesitation.
Hope this helps
Mike
Hey mate,
i just went to the Mechanic last night and i've discovered its my O2 sensor that it buggered.
being a GTR and having 2 the mechanic unplugged one of them and it got worse, so he plugged it back in and unplugged the other and its running a lot better now. still not 100% still stutters a little at times.
so now i guess i am up for some O2 sensors.
but i think i am gonna need to clean my AFM's, when i put my pods on i noticed that they were a little bit oily and the K&N pannel filter i had in the stock air box was covered in that filter oil, there was even a pool of it in the bottom corner.
the K&N pannel would've filtered good because everything was stuck in it!
like the bloke above said too, the O2 sensor ensures that the mixtures are correct by measuring the exhaust gasses and adjusting fuel to ensure that the mix is correct.
its kinda a pain that i have to change the O2 sensors because of the extra $$$ i gotta spend. but at least i know what the problem is now.
Brezza
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
