hey pplz wrecking my 32 GTR car is complete so anything not listed here ive deffinately got but heres the main things.
Blitz SBC - 300
Recaro drivers seat with rail 500
Guards 250 each
bonnet 550
Front bar with lower lip (lower liphas a few chips nuffn major) has nI slots 700
Front bar reinforcing 250
R34 GTR N1 turbos part # 707160-7 minimal shaft pay 1200(pair)
R34 GTR front lower control arms - 300 each
GTR grille- 250
GTR indicators- 150 each
GTR passenger seat - 350
Exhaust control valve- 200
Apexi Stainless steel 3 inch catback exhaust- 700
GTR push type Gearbox- 900
Cylinder head minus cams, cam covers 900
As stated before im wrecking the whole car so if u need anything i havent listed pm me and il get bakc to u asap with a price
All parts located in melb but can send at buyers expense
https://www.sau.com.au/forums/topic/255388-wreckeing-complete-r32-gtr/
  • Replies 62
turbos unsure of how many kms as they came with the car but they have minimal shaft play i drove the car for a week on 1 bar before i toook it off the road for wrecking purposes
recaro is a reclinable no tears or burns etc.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
