i rather walk than use shell!!!
ROFL. That's kinda how I felt as the Vortex was going in.
Hi all,
Im new to all this, i went to fill up 2day and no BP ultimate, so I just filled up with 91, is that bad?? can i get away with it this time....
:domokun:
91 in a tuned turbo car... I would pump out all the fuel out of your tank and replace it with 98 when it becomes available. 91 is for fleet/company/old crappy family cars you don't give a sh*t about. You do know there is Premium 95 at BP if there is no Ultimate 98 right?
  • Replies 53
no bp 98 at sunshine BP too.
i saw the 98 truck on weds when i went to fuel up. but he hasn't start yet or whatever. so i put in 95. came back today, and nope still no 98. so 95 again for me , that's not bad on a non turbo r33 right?
guy told me that there;s no 98 till next week
i found it didnt like as much timing in the datto, and it ran crappy, and stagea feels like arse on it, mrs's old supra did too... datto's head gasket went on shell, only fuel friends have done head gaskets on is shell, so i will follow my theory that you may think is silly, and i will say i dont like it!
My mechanic did his gaskets in his rally car with Shell.
He said the fuel is too dry for the car and he said something about Optimax containing Toilean (Spelling). Well thats his own experiance anyway...
Thats probley the additive cleaning agent to keep the engine clean, but dries it out at extreme temps hence your gaskets going.
So he needed a 'wetter' fuel, so BP or Mobil was the go and no probs after that.
Im sure there are other factors involved.
Back on topic, I filled up with Mobil Synergy 8000 98 RON.
haha, happens that my motor in my 16 was an ex-rally motor freshened up
Ultimate deliveries are increasing.
Now also on Melton Hwy in Taylors Lakes outbound
Bell St in Corurg got a delivery at 4:30pm today I filled up there at 5 as I saw it pull in 30mins before and was just around the corner. Nothing like fresh fuel.
Still none at Melton BP on High st though
Fuel on Nepean Hwy/North Road BP ultimate with no issues last night, I think its starting to get back into stock.
Apparently nearly all 98 is coming from the Mobil refinery, not including Shell Optimax
Man, dunno how many times I have said it, probably not many actually. BP DO NOT get their fuel from the Mobil refinery! They have their own refineries Kiwana in WA comes to mind. Look here post 26
Then for more info
Look Here
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
