Hi there all,
short intro!
I am new to SAU & new to forums!
Have recently purchased an R32 GTR. I think it is a barrel of laugh's (hense my user name). The vehicle is stock standard no boost controller only nice exhaust system.
Just wanted to know what engine oil would be recommended for a gtr r32 rb26dett in track use?
Do you think it would be safe to use standard sump and oil pump for super sprint and hill climb use?
The Big Laugh !
G'day Jay...
Best oil for track use IMO and most of the guys who track their R's here in Vic use Castrol Edge 10w60.
Secondly, for limited track use and the type of events you have indicated the std sump and oil pump will be fine - just keep in mind that oil pumps or the oil pump drive in the 32's are known to be weak points due to age and design. I would consider a new one with upgraded pump drive collar just for piece of mind. What I would highly recommend is a decent oil cooler with ducting etc.
Motul Chrono V Competition 15w50, best there is but not cheap.
Standard sump and oil pump are fine if they are in good condition, Overfill it a bit just in case though when u take it to the track.
If you think your stuff is in good condition then happy racing :happy:
I used Castrol Edge 10w60 for a while but have swapped to Penrite Sin 10w70 and haven't had any issues. You will probably get 10 different answers to your question as everyone has a different opinion etc...
Thanks Guys,
Thanks for the tips. I hope that I can be of some assistance some day.
I have been a bit worried about running with standard sump and oil pump, I probably will change things later if the engine gets pulled out. I have been watching the oil pressure and oil temp guage a lot just driving around town. Have noticed oil pressure has been good (4 @ 4,000rpm) when temperature is nice and hot when under load. But when it idles before shutting down the pressure drops too I guess the 2 mark (half way between 4 and zero). Ambient temp has been 35 to 39 degrees. Does this seem to be ok ?
I have also heard to run extra litre of oil. Is this too much ?
I am getting a catch can made up so if it is too much it could vent and not cause the seals to blow out and start leaks. Do you think it would help ?
Thanks
Jay
Thanks Guys,
Thanks
Jay
I still have the standard sump in mine and run an extra half to one litre of oil, a few of the Vic guys do that from what I've read.
A catch can will help especially once out on the track and an oil cooler will definitely help out as well.
Ran mine on the track with stock bottom end an eventually killed it by then was running cams uprated turbos semislicks etc.
keep it basically stock boost etc street tyres you should be fine
oil cooler and slight overfill as mentioned are cheep insurance and worthwhile I think
bet ya cant keep it stock long though!
Start saving & hoarding parts now for the eventual rebuild though
How much hp did you run to kill your motor?
    • You're not the first person that's said that about this car lol. A Touring wagon GT in Spark yellow mica would be the dog's danglies 😆 I will keep an eye out for a future purchase for sure. The seats are almost like the OEM Recaros... electric adjustment for fore/aft and tilt movements except reclining.
    • Yes!! I love these! It's a shame its not the wagon though!   Thank everything that's holy that it doesn't have the interior of the Aussie delivered ones. Those seats are so much nicer.
    • I'm both sorry and thankful that you do that.
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
