Look Raegan, no one is denying your setup is tough, you have the quickest car in your class in your country and you do it all yourself which is friggin awesome. Its a great credit to you and whoever helped you.
What happened in Chille? post up pics!!! post up dyno sheet as well
and as for you floggin my car... Everyone talked it up and said that to me has learnt the hard way.. besides i am over drag racing i don't even think i will drag race it again.
You're just skeeeered of him aint ya guilt. ;)
  • Replies 136
He lives in Peru.. we could argue about who's car is faster untill the letters wear off on our keyboards! I aint going to be able to race him to find out who is quicker so I aint really interested in the arguement. However he has already beaten my best et.. so unless i go back and finally run a 10 he is faster then me anyway.
I guess what happens in peru stays in peru.
apparently he went to chille to race some gtr's etc etc.. he wont tell us how he went!
How did you go in Chille ? its okay if the GTR's flogged you. they are a car of their own anyway.. would be like me racing the Dirt man.
Did the stock bottom end let go in chile?
lol.. its far from stock. i remember he put it together without giving the block a light skim.. seems to be holding up good though ;)
1992 msdos dyno readout ftw :)
jokes, well done mate!!! like other have said, around 370-380rwkw would be a more realisitc measure for that mph
that was an old trap with an old tune at lower boost and lower timing 3 degrees of timing nad 2 psi of boost
When when are you re-running it ? and .....
WHAT HAPPENED IN CHILLE?!?
it actually checks out...my car running in HPI a while ago (Garage Saurus R32 on the cover) ran 10.36 @ 134 MPH and vehicle weight was 1474KG without my 105kg lard included. Car was running 27psi and was dyno'd at 404AWKW the day before.
gtst should get bigger mph then gtr though??
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
