  • Replies 47
Posted Images
Thats probley your best bet and then you can see if its even wired up and if so, where does it lead to...
No its not, if he ever finds out what it is this thread dies, that must be stopped at all costs!!!
It's a mystery switch!! If you knew what it was, it would no longer be a mystery thus negating the need for it anymore cos you don't want a switch in your car that you know what it's for! Also it would need to be re-named and this thread title would have to change. lolz
It changes your horn over to the one the Dukes have...
It's clearly for a parachute
Do Machine guns or rocket launchers apper from the fron or side of the car?
LOL!
No, still haven't figured it out. Will keep fiddling with it.
Do you have the Nismo MFD? If so I would say it is the start / lap button for the built in lap timer. :domokun:
No, have the standard non-vspec MFD.
My mate used to have one of those in his GT-Four. It was just hooked up to a boost controller, low boost or high boost.
They also have switches similar to this for some fuel pumps dont they?
Have standard fuel pump. Not sure... could be low/high boost I suppose. Will have to find out.
Its a switch for the onboard computer that drives the car for you, that truckers have from the Simpsons. & if you put it in a really bad situation it would say "I'm sorry Mr <insert name here>, the situation is impossible" then it parachutes itself outside the car.
That or its the SSJ power switch, gives you engine an anime style power up, making its power level over 9000!!!
...also exploding all your drive shafts & gear boxes in the process of powering up, which is why the disabled the thing...
LOL!
The Mystery Switch Thread, will we ever find out what it is or does..?
I can tell its gonna get really funny with all the ideas we can think of.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
