geez cut the shit out of the metal front bar ...
hm..... double pass cool, havent yet found one, plus im a perfectionist, thats why i got the FMIC i have, so the front looks even.
might be a long process.
the one with the pipe going behind the radiator in freddy's post. would that affect turbo response being such a long return pipe ?
who installed it and how much? i still havent haha, went to do it last night then realised we didnt have a big enough grinder
here is a pic of a just jap stealth fitted.
Nice job,but ,did you reposition your oil cooler?I allways had the doubt if the 3 layers(fmic/cooler/radiator)don't create a "hot spot" slowing the air flow...
  • 3 weeks later...
found it
quick bump to this thread and a heads up for people wanting to get a aftermarket cooler
out good friends at ARC have the solution
http://www.skylinesaustralia.com/forums/Ar...it-t258630.html
Yep that's exactly what I'm after (although it would end up costing over $1200 NZ by the time I get it here)! However it would be cost efective for an Aussie because there is no installation expense - it will more or less slot straight in.
I believe the ARC item is bigger than the Trust (which is bigger than the R34GTT/neo one) so should be good for around 220AWKW. In other words it would be good for some one who doesn't want a front mount showing (for aesthetic or compliance reasons) but plans on more power.
wish i saw that before i got my FMIC
found it
That intercooler doesn't look much bigger than the standard S2 one(maybe good upgrade for a S1) as the R34Gtt fmic upgrade says in the DIY section:
Time to measure it up, the core is 80 mm thick, compared to the standard Stagea's 65 mm. The core is 210mm wide and 225mm high (18 rows) while the standard Stagea intercooler is 210mmmm by 185mm (15 rows). This would indicate an improvement in flow of 23%, R34GTT is 206kw and Stagea is 170kw, that's a 21% improvement in power. Seems logical that Nissan would have some mathematical basis for upsizing the intercooler
maybe the arc has better air flow?but for $880...
anyway looking around find this(the price is a little bit crazy I recon ),but is another option...
http://www.avoturbo.com/avoshop/product_in...products_id=241
plus the old VL turbo one (BTW there was one on sale on eBay for 100)
http://www.avoturbo.com/avoshop/product_in...products_id=224
after all the research think to keep the standard one until boost goes up...:-)
mount it on the the angle to avoid the reo.
in the cooler thread page 5 i think, a dude's got one on, he didn't cut nothing ! :P
did he remove the thermo? as i dont see what he did as possible, then again, its chinese, they are prob all different
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
    • But if you had to go bury a body in the forest, would you not put that in the boot? Most of them are >=90kg these days.
