I got this R33 skyline like 2 months ago.. Within this 2 months i had spent like $4000 for all the repair bit. The first problem was a broken clutch, then follow up with a burst radiator and then the heater spoil. I am really broke now. T
Then now come out with a new problem. According to the mechanic, he said that my turbo charger is spoil and is starting to suck up all the engine oil and leak out thru the seal. Then he quoted me around $2500 to fix it. Let me rephrase. That's actually not fixing but to get a new turbo charger. Is the price reasonable? Is it better to go for second hand one?
Anyway, have a thought in my mind..... Is it worth keeping for this car???
Please help me....
Thanks heaps
https://www.sau.com.au/forums/topic/25606-my-skyline-starting-to-piss-me-off/
Sounds like all that it needs is a replacement of the turbo seal?!! You can do it yourself if you want to put a few hours in, and for maybe $100 for the gasket.
Sounds like they're also charging you for a brand new whole turbo from factory, when a 2nd hand will do you fine, assuming there is actually a major problem with the turbo (doubtful).
man, I recommend you get another mechanic who isn't trying to rip you off.
p.s. the turbos job *is* actually to suck up a bit of oil from the engine, that keeps it lubricated and running. Its perfectly normal (although leaking is of course not).
that's why u have to fix yr car for that amount of $$.
for the $$ u spent, u should already got a twin plate clutch, aluminium radiator for less than $4000.
rebuild the tubro is about $500-$1000 from my memory...
$2000 u can get NEW aus made aftermarket tubro.
Thanks for the help ppl.
I have just got my car back from the mechanic.
He was quite pissed when i told him that i gonna get the turbo charger from someone else for $500. He said it's impossible unless it's a second hand one.
So, probably my car going to lie in the garage for quite sometime before i can get a new turbo. Anyone in this forum mind to tell me where can i get one? and how much is it?
"$2500 for a new turbo would get you a nice Ball bearing Garrett turbo. "
At the same time, i think if i spend $2500 to get a aftermarket turbo charger like wat "GTST" said, isn't i need to change all other stuff like fuel injection and other stuff. So gonna cost more right?
Anyway, i really looking forward for a turbo charger. Please tell me where to get one or PM me if u got one.
Thanks again
SkylineD, think of it like this:
Imagine it was the other way round, and the japanese took a liking to buying ex p-plater VN commodores. Imagine said thrashed old commodores getting tarted up , stuck on the boat, and sold for exorbitant mark ups to little japanese bogan kids.....
Now do you see why so many people get bodgy GTS-T's?
cheers,
floody
$4k for a clutch and faulty cooling system is a joke. The first thing I would do is ditch your mechanic.
The three problems you have are not really that major. I wouldn't get rid of the car unless you know it has other problems, like worn rings or something. Get yourself a second hand turbo and stick with it. You should be ok from there.
im having troubles with mine after only owning it for 2 months.
*Fuel tank leak
*Slipping Clutch
*About to spin a big end bearing
*Blue smoke blowing from engine(oil ring or valve stem seals)
*Interior fan no longer works
it only done a 60000klms and thus shat is going wrong already. Cant afford to have these problems :D so i know how ya feel buddy
Yowch sweetr33!
Well i'll admit i've got my own motivation by saying this, as i'll be selling mine soon...but there are a lot of dodgy skylines out there. You're best off buying privately and from somebody where you know the history of, and has at least been on our roads for a year or more. Even if its been imported, a service history and knowing the seller has cared for it is worth gold.
I think those people out there shopping for a $15k GTS-T because "my mate got one for $15k... and on the presige list i can bring one in for $16k, you're a dickhead for trying to sell yours for $18k" are shooting themselves in the foot to be honest.
But yup, i'm with Floody.. imagine if a car yard could offload all its thrashed old Commondoors and things that nobody wanted on a boat to a country the other side of the world they're never going to see again. You get good and you get very bad.
howhow82
it's called 'teething problems' and with some cars it's like pulling out wisdom teeth while with others it's a simple floss. you were just unlucky to get stuck with what sounds like a rip off mechanic. keep the car, get a new mechanic (sounds like you already gave him the flick) and ask for advice on the forums. there's always someone that'll help you.
sweetr33,
are you sure that car has done only 60,000kms?
post up his shop name let other people beware of going there
go GCG to rebuild yr own one, so u can run higher boost (1.1 or 1.2bar) too
:uh-huh:
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
