as tittle says, been trying to find some pic's of how it's done..
i know the head is drilled and tapped and a fitting is put in then a return line is fitted and another hole is drilled and tapped to the sump..
where exactly is this done on the head...eg front, left side, right side, back ect..
where exactly is this done on the sump... front, rear ect...
any one got any pics to show us???
Any help much appreciated
Aaron
https://www.sau.com.au/forums/topic/256106-head-to-sump-oil-return/
hey man, from what i can tell it goes from the top welsh plug at the back of the engine, and down to the sump (un sure where) it goes under the plenum side so im guessing anywhere really aslong as its higher than all the oil so it works well,
got a pic, i took it from the oil control thread on this forum, may be some more pictures? would be worth a look?
heaps of people just fabricate a fitting to do the job. the return is then plumbed back into the sump on the plenum side becasue of the way the crank turns it helps to promote flow into the sump and not get sloshed back up from the crank.
Aaron
TUFFRX3 ,makes dash 10 and dash 8 press in fittings for the oil drain off the back of the head ,i have just brought some .no drilling needed ,just press it in and its done .i think he has some pix loaded in the for sale section
cheers
They really are not needed...
i have been told this to by my tuning shop is this true guys? im just building my engine now it has a greddy oil pump got a oil restrictor for head and trust sump extension do i need this return line?
cheers for the pic sly32...
what i read must have been way off, those welsh plug oil drain seem to be the way to go....
cheers to r33cruiser i'm definetly getting one from spool,
only $110 for the oil drain or $250 for the kit with the oil drain, speedflow fittings and hose...
Edited by vspec_gtr32
the questions is... i hear ppl call them just a bandaid fix to a problem... ne other comments on whether there really needed
not required...they dont drain anything substancial...they actually vent the sump on big clearanced race engines. On a properly built street engine they are waste of money, time and damage to firewall.
Notice two fuel rails on the picture supplied in post #2 (it was from another thread that i posted this picture in) Its a big $$ big clearanced racing engine.
Edited by DiRTgarage
cheers
And IMO, they're shit.
I have one on my R33... There is NO CHANCE you can ever fit the 90 degree bend whilst the head is in place, without unbolting the engine mounts and lowering the engine.
Once you have it on, it sits in the way of the heat hoses, and then, still sits hard against the firewall.
If I had my time again, I wouldn't do it.
Forgot to mention, I'm only running the dash 8... No idea how the people with Dash 10s fitted theirs!
Edited by MBS206
couldnt agree more.. sure there cheap.. but not suited at all.. the ones from spool are a much better option!
Well its been covered in past threads if he needed to find out why, but then its been posted in here as well since
i know it has.
i was just bringing to light ur yet again hypocritical ramblings. ur the first to pull up others on totally useless posts that have a suggestion but no fact to back them up.
just keeping u on ur toes :D
paul, im curious to know how the drain vents the sump. i have a rough idea of where ur going but if u wouldnt mind can u elaborate please
i know it has.
no fact? easy now :D
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
