I have done a search and there are various discussions about wheel dimensions / offset / size etc. but most of the relate to WC34 S I & S II.
I'm wondering what is the best fit (i.e. no tyre scrubbing on guards etc.) for a M35 with standard issue brakes.
I'm not in the market to fit new tyres to the vehicle yet but wouldn't mind looking around to see what's available as the standard issue 17's look a bit bland :D
I'm hoping on doing heaps of driving in the first year of owning the car, hopefully wear down the current tyres on it so I can fit some newies.
Thanks for your help guys.
Stephen
https://www.sau.com.au/forums/topic/256200-wheels-for-m35/
  • Replies 59
I'm not in the market to fit new tyres to the vehicle yet but wouldn't mind looking around to see what's available as the standard issue 17's look a bit bland :P
Stephen
Pretty Sure there the same as a BA-BF Falcon.....well at least mine are.(19in x 8.5in)
also check out the site below
http://www.fujicorporation.com/eng/sim/ind...%3Aw_id%3D22455
https://www.sau.com.au/forums/topic/256200-wheels-for-m35/#findComment-4416212
Thanks for that man, I was hoping there would be an easy fit and not a custom drill job or anything to get them on.
I see in the picture your car (I assume it's yours?) has red on the rim? I'm looking at something similar, could be identical but I can't tell from the pic.
The Speedy Vapor Redline is only available in 18 x 8 :)
Or the Speedy Cheetah Gloss Black is available in a 19 x 8.5 :)
https://www.sau.com.au/forums/topic/256200-wheels-for-m35/#findComment-4416656
I believe the offset should be the same as newer Skylines. I've got V35 Skyline 350GT wheels (18x8s with a +30 offset) on my s1 C34 and only had to roll my rear guards due to the width of my tyres (245s all round)...
https://www.sau.com.au/forums/topic/256200-wheels-for-m35/#findComment-4416893
The Speedy Vapor Redline is only available in 18 x 8 :D
Or the Speedy Cheetah Gloss Black is available in a 19 x 8.5 :P
Got my wheels from Jax at Thornleigh(NSW).
Also check out this site:
http://www.tempetyres.com.au/products.asp?...9+Inch+Packages
https://www.sau.com.au/forums/topic/256200-wheels-for-m35/#findComment-4418271
IMHO they don't suit the car that well, they look too much like a DTM racing car style!
consider simply looking for a lightweight 5 or 6 spoke rim with a bit more 'pizzazz' than the stock rim, so it stands out without screaming 'tempe package deal'.
huh! :P your opinion!!!....lol....and thanks for your opinion.
pizzazz?.....screaming 'tempe package deal'?....WTF!.........maybe you should point us all in the right direction....got pic's of what your talking about?
P.S. DTM racing was what I was after....bling doesn't do it for me....either do 12 slot's :down:
Edited by Jetwreck
https://www.sau.com.au/forums/topic/256200-wheels-for-m35/#findComment-4418639
Pfft, each to their own... Like they say, opinions are like ar5eholes, everyone's got one!
I like the way those wheels look on Jet's car - personally I wouldn't have chosen them because I don't really like black wheels, but seeing as they're a mesh-style wheel and would be a PITA to clean, at least you won't notice the brake dust on them.
https://www.sau.com.au/forums/topic/256200-wheels-for-m35/#findComment-4418662
whoa dude, i wasn't having a go at you personally, just stating my opinion on those rims. I just think DTM style rims look better on 90's euro cars and don't look good on late model japanese cars.
chromies are a definate no-no too, but i prefer something more like this.
http://www.tirerack.com/wheels/WheelCloseU...te+w%2FMach+Lip
https://www.sau.com.au/forums/topic/256200-wheels-for-m35/#findComment-4420674
I'm DEFINITELY with you on the chromies - why the heck would you buy a sports car, spend money on making it handle and perform better, then throw it all away on ugly and heavy chromies.
Once again, it's each to their own, but in this case, thank f*ck for that - there are some "trends" that will never make sense to me. After all, following a trend or fashion doesn't mean you automatically have a sense of style!
https://www.sau.com.au/forums/topic/256200-wheels-for-m35/#findComment-4420683
  • 2 months later...
Hi Gents, Ive got some wheels lined up, can anyone confirm 19" x 8.5", Rear - 19" x 9.5"
Offset: 30mm (Front & Rear) (No Dish)
PCD: 5x 114.3mm
would fit the M35 ARX, will the offset make the wheels rub on anything? what is your wheel fit and offset?
Edited by hydra
https://www.sau.com.au/forums/topic/256200-wheels-for-m35/#findComment-4557455
PCD: 5x 114.3mm
You will need to confirm with those more knowledgeable on the site but I think I've seen mentioned a few times that the tyre sizes MUST be the same or not majorly different.
I think it has something to do with the ATTESSA system?! (AWD)
https://www.sau.com.au/forums/topic/256200-wheels-for-m35/#findComment-4557545
245 front 265 back, I read that aswell, in my search somewhere aswell before I posted. He mentioned that if the rolling diamter is different would wear out the transfer case for some reason or another, Im mainly concerned about rubbing ect on the inside or on the arch?
Edited by hydra
https://www.sau.com.au/forums/topic/256200-wheels-for-m35/#findComment-4557570
+ 1. Need to be the same size or you will screw up the ATESA system.
Offset that i think most people have used effictively is +36.
It depends a bit on if you want to upgrade the front brakes.
Cheers
Andy
You can run staggered sizes as long as the ROLLING DIAMETER is the same, i.e; 245/45/18 & 275/40/18 have the same rolling diameter, accurate to .01%. Use the tyre size calculator on the site to check, sometimes it can be a real faff to get right.
Seems like the +30 on a 9.5" might be a squeeze, if the stockers are a +45 8"
Andy, was that +36 offset on an 8" rim?
Edited by Daleo
https://www.sau.com.au/forums/topic/256200-wheels-for-m35/#findComment-4558075
but remember - and its been mentioned before - when a tyre is put on a wider or narrower rim than reccommended, the rolling diameter changes. so IMO its best to have it the same all the way around so you dont do damage
https://www.sau.com.au/forums/topic/256200-wheels-for-m35/#findComment-4558094
I agree, the other alternative is staggered offsets, that way you can push the rims right out to the guards and you can still rotate tyres, they just have to be swapped on rims.
The same width/ offset front and rear is much more practical, day to day.
Personally, I think 18x9 or 19x9 with a +45 offset would be hard to beat for filling the guards and for sheer prescence.
Don't know how you go legally tho'.
Edited by Daleo
https://www.sau.com.au/forums/topic/256200-wheels-for-m35/#findComment-4558116
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
