Hi everyone.
I bought a CAMS approved fire extingusher, so i could enter track days. :banana:
My plan was to mount it in the passenger footwell, but there is a bump where the exhaust passes making it a tight fit.
The car is a 97 Type X 180sx.
Here is some pictures of trial fitting.
Any suggestions on where I can mount it?
Cheers
https://www.sau.com.au/forums/topic/256719-fire-extingusher/
Don't you need to be able to get to it pretty quickly if need be? If so I would mount behind the drivers seat on the B Pillar, that's where I had it in the rally car :(
If you braked suddenly or crashed, wouldn't that just fly off and make a crater in the back of your skull?
i've tried to put the fire extingusher as in pic.3 but it is very hard to reach it from the drivers seat with the seatbelt on, so it is not very likely to be a practical mounting point :(
Ummm... if my car was on fire, I would not keep driving with my seatbelt on, but stop the car and undo my seatbelt. Just personal opinion though :laugh:
Ummm... if my car was on fire, I would not keep driving with my seatbelt on, but stop the car and undo my seatbelt. Just personal opinion though :(
Me too lol
Another good spot is on the floor behind you just under the front of the rear seats if that makes sense. Drivers or passengers - which ever is easier for you to reach..
I was thinking of mounting it on the drivers side, but was told that it is not a very good idea if it explodes :( (not sure how many cases are there of that happeining) :laugh:
I tested reaching the extingusher with the seatbelt on, coz just in case your seatbelt is jammed or something after a crash and you mounted your extingusher too far.
I guess i could mount it on the side in the passenger footwell but also but a carboard-cutter knife or something in the center console just in case the seatbelt gets jammed.
As long as you don't have a 20-year old fire extinguisher corroded to the max, it won't explode.
In the event that pressure builds up inside the canister for whatever reason, there is an automatic "Wastegate" in all extinguishers that lets out the pressurised contents once they reach a certain pressure. I think mythbusters threw an extinguisher in a fire, and it didn't do anything, thus debunking that myth.
In the case that an explosion so violent does not give the canister enough time to vent through the wastegate, I would say, you're dead in the first place anyway.
Under the drivers seat is probably the best place to mount it. If it does explode, you have the cushioning of the hard flame-retardant recaro seats and your own derriere. If it is in sight, it will likely kill/blind you. In any case, an explosion in the cabin is probably lethal in any position.
this is legal for track.
use nuts and bolts, not self tappers.
the only place you can put it where you will reach it with a harness is on your centre console. putting it under your seat makes getting to the back very hard.
Mine is in the exact spot as Ryan's, near the centre console. Personally with a harness I reckon it would be one of the easiest locations to reach in an S13
Err no! I suppose if it wasn't mounted well it could fall off but it would hit your seat not your head! Unless you are a little person in which case you'd be propped up to see over the dash.
Seriously it fits well there, you can get to it with a tight harness on if need be and it doesn't interfere with anything, you can even mount it there with a cage!
Mines on the floor in the front between the seat mounting points under the seat on the drivers side.
The standard seat moves unrestricted as if it was not there.
CAMS scruitneers love it as i can reach it with a harness.
thanks everyone :D
I will trial fit it in the driver footwell tomorrow and see if i can still slide the seat with no problems, hopefully it all work fine
hopefully get my shit together to enter the DECA on the 28th
on the offtopic, does anyone know where i can buy some Lucas(TWR) Grand Prix RBF600 brake fluid?
Cheers
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
