180Roman Posted February 12, 2009 Share Posted February 12, 2009 Hi everyone. I bought a CAMS approved fire extingusher, so i could enter track days. My plan was to mount it in the passenger footwell, but there is a bump where the exhaust passes making it a tight fit. The car is a 97 Type X 180sx. Here is some pictures of trial fitting. Any suggestions on where I can mount it? Cheers Link to comment https://www.sau.com.au/forums/topic/256719-fire-extingusher/ Share on other sites More sharing options...
Bennett Posted February 12, 2009 Share Posted February 12, 2009 Put it how you have it in the last pic. That always works well Link to comment https://www.sau.com.au/forums/topic/256719-fire-extingusher/#findComment-4421934 Share on other sites More sharing options...
adznight Posted February 12, 2009 Share Posted February 12, 2009 I agree Link to comment https://www.sau.com.au/forums/topic/256719-fire-extingusher/#findComment-4422047 Share on other sites More sharing options...
BeEnAr Posted February 12, 2009 Share Posted February 12, 2009 Don't you need to be able to get to it pretty quickly if need be? If so I would mount behind the drivers seat on the B Pillar, that's where I had it in the rally car Link to comment https://www.sau.com.au/forums/topic/256719-fire-extingusher/#findComment-4422061 Share on other sites More sharing options...
Phatboy Posted February 12, 2009 Share Posted February 12, 2009 Don't you need to be able to get to it pretty quickly if need be? If so I would mount behind the drivers seat on the B Pillar, that's where I had it in the rally car If you braked suddenly or crashed, wouldn't that just fly off and make a crater in the back of your skull? Link to comment https://www.sau.com.au/forums/topic/256719-fire-extingusher/#findComment-4422141 Share on other sites More sharing options...
180Roman Posted February 12, 2009 Author Share Posted February 12, 2009 i've tried to put the fire extingusher as in pic.3 but it is very hard to reach it from the drivers seat with the seatbelt on, so it is not very likely to be a practical mounting point Link to comment https://www.sau.com.au/forums/topic/256719-fire-extingusher/#findComment-4422222 Share on other sites More sharing options...
Phatboy Posted February 12, 2009 Share Posted February 12, 2009 Can you mount it under the front of your drivers seat? Link to comment https://www.sau.com.au/forums/topic/256719-fire-extingusher/#findComment-4422231 Share on other sites More sharing options...
Phatboy Posted February 12, 2009 Share Posted February 12, 2009 i've tried to put the fire extingusher as in pic.3 but it is very hard to reach it from the drivers seat with the seatbelt on, so it is not very likely to be a practical mounting point Ummm... if my car was on fire, I would not keep driving with my seatbelt on, but stop the car and undo my seatbelt. Just personal opinion though Link to comment https://www.sau.com.au/forums/topic/256719-fire-extingusher/#findComment-4422234 Share on other sites More sharing options...
Bennett Posted February 12, 2009 Share Posted February 12, 2009 Ummm... if my car was on fire, I would not keep driving with my seatbelt on, but stop the car and undo my seatbelt. Just personal opinion though Me too lol Another good spot is on the floor behind you just under the front of the rear seats if that makes sense. Drivers or passengers - which ever is easier for you to reach.. Link to comment https://www.sau.com.au/forums/topic/256719-fire-extingusher/#findComment-4422291 Share on other sites More sharing options...
180Roman Posted February 12, 2009 Author Share Posted February 12, 2009 I was thinking of mounting it on the drivers side, but was told that it is not a very good idea if it explodes (not sure how many cases are there of that happeining) I tested reaching the extingusher with the seatbelt on, coz just in case your seatbelt is jammed or something after a crash and you mounted your extingusher too far. I guess i could mount it on the side in the passenger footwell but also but a carboard-cutter knife or something in the center console just in case the seatbelt gets jammed. Link to comment https://www.sau.com.au/forums/topic/256719-fire-extingusher/#findComment-4422293 Share on other sites More sharing options...
Phatboy Posted February 12, 2009 Share Posted February 12, 2009 I was thinking of mounting it on the drivers side, but was told that it is not a very good idea if it explodes As long as you don't have a 20-year old fire extinguisher corroded to the max, it won't explode. In the event that pressure builds up inside the canister for whatever reason, there is an automatic "Wastegate" in all extinguishers that lets out the pressurised contents once they reach a certain pressure. I think mythbusters threw an extinguisher in a fire, and it didn't do anything, thus debunking that myth. In the case that an explosion so violent does not give the canister enough time to vent through the wastegate, I would say, you're dead in the first place anyway. Under the drivers seat is probably the best place to mount it. If it does explode, you have the cushioning of the hard flame-retardant recaro seats and your own derriere. If it is in sight, it will likely kill/blind you. In any case, an explosion in the cabin is probably lethal in any position. Link to comment https://www.sau.com.au/forums/topic/256719-fire-extingusher/#findComment-4422332 Share on other sites More sharing options...
180Roman Posted February 12, 2009 Author Share Posted February 12, 2009 would the police say anything about having an extingusher under the drivers seat? Link to comment https://www.sau.com.au/forums/topic/256719-fire-extingusher/#findComment-4422384 Share on other sites More sharing options...
Belsil80 Posted February 12, 2009 Share Posted February 12, 2009 this is legal for track. use nuts and bolts, not self tappers. the only place you can put it where you will reach it with a harness is on your centre console. putting it under your seat makes getting to the back very hard. Link to comment https://www.sau.com.au/forums/topic/256719-fire-extingusher/#findComment-4422491 Share on other sites More sharing options...
RBPOWA-(TJ) Posted February 12, 2009 Share Posted February 12, 2009 Can you mount it under the front of your drivers seat? yep thats where mine is goin. seen it dont before. cause your feet are at the pedals. just gotta watch your step in and out of the car Link to comment https://www.sau.com.au/forums/topic/256719-fire-extingusher/#findComment-4422530 Share on other sites More sharing options...
Liz Posted February 12, 2009 Share Posted February 12, 2009 I've mine mounted between the front front seat mounts... easy to install and really easy to reach if you need it! Link to comment https://www.sau.com.au/forums/topic/256719-fire-extingusher/#findComment-4422656 Share on other sites More sharing options...
Do-Luck Posted February 12, 2009 Share Posted February 12, 2009 this is legal for track. use nuts and bolts, not self tappers. the only place you can put it where you will reach it with a harness is on your centre console. putting it under your seat makes getting to the back very hard. Mine is in the exact spot as Ryan's, near the centre console. Personally with a harness I reckon it would be one of the easiest locations to reach in an S13 Link to comment https://www.sau.com.au/forums/topic/256719-fire-extingusher/#findComment-4422685 Share on other sites More sharing options...
BeEnAr Posted February 12, 2009 Share Posted February 12, 2009 If you braked suddenly or crashed, wouldn't that just fly off and make a crater in the back of your skull? Err no! I suppose if it wasn't mounted well it could fall off but it would hit your seat not your head! Unless you are a little person in which case you'd be propped up to see over the dash. Seriously it fits well there, you can get to it with a tight harness on if need be and it doesn't interfere with anything, you can even mount it there with a cage! Link to comment https://www.sau.com.au/forums/topic/256719-fire-extingusher/#findComment-4422784 Share on other sites More sharing options...
racegtst Posted February 12, 2009 Share Posted February 12, 2009 Mines on the floor in the front between the seat mounting points under the seat on the drivers side. The standard seat moves unrestricted as if it was not there. CAMS scruitneers love it as i can reach it with a harness. Link to comment https://www.sau.com.au/forums/topic/256719-fire-extingusher/#findComment-4423136 Share on other sites More sharing options...
180Roman Posted February 12, 2009 Author Share Posted February 12, 2009 thanks everyone I will trial fit it in the driver footwell tomorrow and see if i can still slide the seat with no problems, hopefully it all work fine hopefully get my shit together to enter the DECA on the 28th on the offtopic, does anyone know where i can buy some Lucas(TWR) Grand Prix RBF600 brake fluid? Cheers Link to comment https://www.sau.com.au/forums/topic/256719-fire-extingusher/#findComment-4423250 Share on other sites More sharing options...
