Hi everyone.
I bought a CAMS approved fire extingusher, so i could enter track days. :banana:
My plan was to mount it in the passenger footwell, but there is a bump where the exhaust passes making it a tight fit.
The car is a 97 Type X 180sx.
Here is some pictures of trial fitting.
Any suggestions on where I can mount it?
Cheers
https://www.sau.com.au/forums/topic/256719-fire-extingusher/
Don't you need to be able to get to it pretty quickly if need be? If so I would mount behind the drivers seat on the B Pillar, that's where I had it in the rally car :(
If you braked suddenly or crashed, wouldn't that just fly off and make a crater in the back of your skull?
i've tried to put the fire extingusher as in pic.3 but it is very hard to reach it from the drivers seat with the seatbelt on, so it is not very likely to be a practical mounting point :(
Ummm... if my car was on fire, I would not keep driving with my seatbelt on, but stop the car and undo my seatbelt. Just personal opinion though :laugh:
Ummm... if my car was on fire, I would not keep driving with my seatbelt on, but stop the car and undo my seatbelt. Just personal opinion though :(
Me too lol
Another good spot is on the floor behind you just under the front of the rear seats if that makes sense. Drivers or passengers - which ever is easier for you to reach..
I was thinking of mounting it on the drivers side, but was told that it is not a very good idea if it explodes :( (not sure how many cases are there of that happeining) :laugh:
I tested reaching the extingusher with the seatbelt on, coz just in case your seatbelt is jammed or something after a crash and you mounted your extingusher too far.
I guess i could mount it on the side in the passenger footwell but also but a carboard-cutter knife or something in the center console just in case the seatbelt gets jammed.
As long as you don't have a 20-year old fire extinguisher corroded to the max, it won't explode.
In the event that pressure builds up inside the canister for whatever reason, there is an automatic "Wastegate" in all extinguishers that lets out the pressurised contents once they reach a certain pressure. I think mythbusters threw an extinguisher in a fire, and it didn't do anything, thus debunking that myth.
In the case that an explosion so violent does not give the canister enough time to vent through the wastegate, I would say, you're dead in the first place anyway.
Under the drivers seat is probably the best place to mount it. If it does explode, you have the cushioning of the hard flame-retardant recaro seats and your own derriere. If it is in sight, it will likely kill/blind you. In any case, an explosion in the cabin is probably lethal in any position.
this is legal for track.
use nuts and bolts, not self tappers.
the only place you can put it where you will reach it with a harness is on your centre console. putting it under your seat makes getting to the back very hard.
Mine is in the exact spot as Ryan's, near the centre console. Personally with a harness I reckon it would be one of the easiest locations to reach in an S13
Err no! I suppose if it wasn't mounted well it could fall off but it would hit your seat not your head! Unless you are a little person in which case you'd be propped up to see over the dash.
Seriously it fits well there, you can get to it with a tight harness on if need be and it doesn't interfere with anything, you can even mount it there with a cage!
Mines on the floor in the front between the seat mounting points under the seat on the drivers side.
The standard seat moves unrestricted as if it was not there.
CAMS scruitneers love it as i can reach it with a harness.
thanks everyone :D
I will trial fit it in the driver footwell tomorrow and see if i can still slide the seat with no problems, hopefully it all work fine
hopefully get my shit together to enter the DECA on the 28th
on the offtopic, does anyone know where i can buy some Lucas(TWR) Grand Prix RBF600 brake fluid?
Cheers
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
