Hi everyone.
I bought a CAMS approved fire extingusher, so i could enter track days. :banana:
My plan was to mount it in the passenger footwell, but there is a bump where the exhaust passes making it a tight fit.
The car is a 97 Type X 180sx.
Here is some pictures of trial fitting.
Any suggestions on where I can mount it?
Cheers
https://www.sau.com.au/forums/topic/256719-fire-extingusher/
Don't you need to be able to get to it pretty quickly if need be? If so I would mount behind the drivers seat on the B Pillar, that's where I had it in the rally car :(
If you braked suddenly or crashed, wouldn't that just fly off and make a crater in the back of your skull?
i've tried to put the fire extingusher as in pic.3 but it is very hard to reach it from the drivers seat with the seatbelt on, so it is not very likely to be a practical mounting point :(
Ummm... if my car was on fire, I would not keep driving with my seatbelt on, but stop the car and undo my seatbelt. Just personal opinion though :laugh:
Ummm... if my car was on fire, I would not keep driving with my seatbelt on, but stop the car and undo my seatbelt. Just personal opinion though :(
Me too lol
Another good spot is on the floor behind you just under the front of the rear seats if that makes sense. Drivers or passengers - which ever is easier for you to reach..
I was thinking of mounting it on the drivers side, but was told that it is not a very good idea if it explodes :( (not sure how many cases are there of that happeining) :laugh:
I tested reaching the extingusher with the seatbelt on, coz just in case your seatbelt is jammed or something after a crash and you mounted your extingusher too far.
I guess i could mount it on the side in the passenger footwell but also but a carboard-cutter knife or something in the center console just in case the seatbelt gets jammed.
As long as you don't have a 20-year old fire extinguisher corroded to the max, it won't explode.
In the event that pressure builds up inside the canister for whatever reason, there is an automatic "Wastegate" in all extinguishers that lets out the pressurised contents once they reach a certain pressure. I think mythbusters threw an extinguisher in a fire, and it didn't do anything, thus debunking that myth.
In the case that an explosion so violent does not give the canister enough time to vent through the wastegate, I would say, you're dead in the first place anyway.
Under the drivers seat is probably the best place to mount it. If it does explode, you have the cushioning of the hard flame-retardant recaro seats and your own derriere. If it is in sight, it will likely kill/blind you. In any case, an explosion in the cabin is probably lethal in any position.
this is legal for track.
use nuts and bolts, not self tappers.
the only place you can put it where you will reach it with a harness is on your centre console. putting it under your seat makes getting to the back very hard.
Mine is in the exact spot as Ryan's, near the centre console. Personally with a harness I reckon it would be one of the easiest locations to reach in an S13
Err no! I suppose if it wasn't mounted well it could fall off but it would hit your seat not your head! Unless you are a little person in which case you'd be propped up to see over the dash.
Seriously it fits well there, you can get to it with a tight harness on if need be and it doesn't interfere with anything, you can even mount it there with a cage!
Mines on the floor in the front between the seat mounting points under the seat on the drivers side.
The standard seat moves unrestricted as if it was not there.
CAMS scruitneers love it as i can reach it with a harness.
thanks everyone :D
I will trial fit it in the driver footwell tomorrow and see if i can still slide the seat with no problems, hopefully it all work fine
hopefully get my shit together to enter the DECA on the 28th
on the offtopic, does anyone know where i can buy some Lucas(TWR) Grand Prix RBF600 brake fluid?
Cheers
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
