Hi all,
I'm new to this forum. I don't own a Skyline but I hope it doesn't mean I can't post stuffs in this forum :(
I need an advice on which Audio Installer to go in VIC (Melbourne Metro preferred), that can do all of my plan below.
I am currently going to get a new Honda Accord Euro (due Nov), and this is my plan:
1. Change the stock speakers to either Boston Acoustics or Focal. The front will be the split system, the middle and the back will just be one piece.
2. Have a custom sub box made since I want to keep my boot space as big as possible.
3. I still have my 2 x 12" Phoenix Gold subwoofer I'm planning to keep for my new car.
4. Get Audison amp(s) to power up my speakers and subs.
Unfortunately I can't change the Head Unit because it's already integrated to the dash.
Do you guys have any other suggestions on which brand I should also look at? I've been told that I should go for Boston Acoustics FS60 for the front speakers, and Audison for the amps.
Upgrading the engine will be my next step, most probably the year after.
Thanks in advance for any adivce.
Originally posted by king_kw13
nice setup
I don't have any suggestions, but i know to stay away from JB, strathfield and autobarns for installs
Totally agree with you on that one. A mate of mine got JB to install his head unit. When I did some work on his car I found the the wires had been twisted and taped instead of soldered or joined with proper connectors. I had to rewire his head unit...
common trick they also is show a higher guage wire to the fire wall then they change it under your trim to really thin shit, but they charge u for the thick wire. Doggy.
try gary's car audio nadawading or in elthem.
patterson sound -blackburn
or get a mate to do it for who knowswhat his doing your job is not to big.
Does the stock Honda head unit have RCA out puts for the amp?
if not u will have to buy an inverter. x2 to get a 4chanel output in RCA format.
Or the amp could have this feature built in most do.
good luck
have and proplems send me a PM
i am currently Studing Electronic's.
I would have no idea until I actually get the car in Nov and have someone looked at it. I doubt it has any RCA output since it's integrated.
Here's the pic of the dash:
Thanks for the advice, I'll look up Gary's Car Audio and Patterson Sound.
yeah i would safely say that is does not have RCA out put, call honda dealer ship andask them. or go to a honda service centre and speak to a an auto elec.
it also may be that a lot or re-wiring to do, if the engine mangement messages go via the head unit. or special function of the car.
good luck
It would only be a matter of time before the industry finally catching up and offer a generic, faceless, audio head unit system with custom specific connection relays that will suit some of those makes and models like Accord Euro...
if ur amps dont have hi-level inputs (speaker wire) then u need a converter thing which costs about $10 at strathfield. it takes in ur 2 speaker wires, and outputs them as RCA signals.
I'd invest $70 or so in an equaliser aswell, as theres no sub out from ur headunit.
there's obviously a loss in quality (hi level inputs) but thats the only way to go about it as far as i can see.
as for front stage, check out this months issue of incar entertainment, they did an excellent review on 13 splits in ur price range. focal 165k2's came out best, but others like boston were up there. If i had the money, i'd go for that (focals). Boston, PG, DLS are other good choices too.
Amps, i'd stick with the audison if u have the $$ to get a nice enough amp to power ur subs adequetly.
Dont go to jb, strathfield autobarn or any place like that. go to someone who sells ur brands. Personally, i'd get the installation done myself and then if ur not good at making a box and stuff, get Gary's or someone to do it. But that's a rip off in my opinion, but what can u do.
I've got a 97 accord, the way im having my subs is a dual chamber box fitted in snugly all the way to the back and so most of the boot (to what u can get to) is still spare.
Nav2k, Where did you get your box made? Can you send a pic of it so at least I'll have a general idea. I'm not after anything fancy as it's not for show :D
I totally agree with you. Most new cars have integrated audio in their dash nowadays. I mean it's okay if they give you one of the best audio system, but instead most of them are shit. :D
tell me about i looked at my dads new Audi and thats a bitch to get out, but the only positive thing is that the stock system is pretty good "Bose" :D But it has no subs, and i ant plaining to rip apart his car just to put a sub in.
i think car companies are doing this delebretly so we dont touch them
im in the process of re-building one now, ill show u after wednesday.
it'll only take a few hours to do, but after vinyl etc. and rest of boot, probably take the whole day.
best thing is find someone to build it for u, provide them with the $30 worth of wood and other materials, and buy them a pizza for lunch
works out a lot cheaper than what gary's car audio would do to snugly fit it in.
I was actually thinking of having fibre glass for the sub box to cut down the weight as my current sub box is bogging my civic down. I did have the box replaced with a lighter one a couple of months ago, but I can still feel the difference with and without the box on board. I guess fibre glass would cost a lot?
its strong, but u'd still need wood to support it from behind for the sub, so basically ur gonna have a lot of wood supporting the fiberglass anyway. My box weighs only about 2 or 3kg, its the subs that weigh about 5kg each in my boot. U need a box to be able to support the subs properly, and to do that u'll need quite a bit of fiberglass if u want to make it just out of that...it could be done....it'd cost a lot for sure.
all those custom boot installs u see in autosalon etc. r done by wood and just fiberglass moulding around it to make it look pretty.
Is it important to have a lining/layer of cotton inside the box? I saw somewhere on the internet (can't remember where) that it's necessary, but I fogot what for. My latest sub box doesn't have that, but it's a ported.
Which one is better anyway, closed box or ported box? What difference does it make?
Oh, and I've also been told that if your car is a sedan, you face the sub inside the cabin, but if your car is a coupe/hatchback, you face it into the boot. Is that true?
I've also seen a lot facing downwards in competition/show.
Originally posted by hippy
u mean u enter ur car into competitions with a dead stock honda sound system??  LOL
I never said I enter my car into competitions ;)
Besides, my current civic had none of the stock system still installed, but it's no way near a competition level :(
yeh the filling is just something to muffle the sound a bit so it feels more punchy kinda than bouncing off the barewood i think. i had it , and didnt like it so took it out, try it out, just use some filling from ur mums old cushions like i did :(
as for porting vs sealing, general rule of thumb, if u want tighter bass with more sound quality u'd go for sealing, and by that i mean complete seal, no air gaps at all etc. (this is what ive got) or porting u get way more bass or spl, but its very important to get the porting right, it needs to be very accurate to be done effectively. i dont know that much about porting and the tuning of the ports (ive read tutorials briefly, so i went for the sealed option). If you port it, follow ur subwoofer specification and make the volume slightly larger than for a sealed box.
for more info, check out www.caraudioaustralia.com and then the tutorials section.
if ur not sure about volumes, use the box volume calculator on caraudioaustralia aswell.
yes, firing them into the cabins r generally more effective.
Having the upside down is for free to air subs, or basically ur just a box (virtual box = whole boot). The quality would definetly be better in a box, but if ur working with 2 subs and u angle them so that the virtual volume is fairly the same...then u can get the same effect.
My accord, i went for sealed (air tight with some wall gap filler for the edges on the insides of the box) to the correct specifications of the subs, and theyre facing outwards (ie if u open the boot u'll see the subs face) .
remember to spend a bit of $$ on sound deadening. i havent done it to my accord cos im looking to sell this december, but ive put aside $250 to deaden the bootlid and doors. The quality will be 1000000000 times better trust me.
go with whatever sounds good to u though, its ur system, u'll be listening to it ,
borrow some friends already made sub boxes
(hell, even buy a box thats ported from jaycar, try it out and say "it didnt fit where i wanted it to, got anything smaller? no? ok ill just take my money back" )
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
