Hey Guys,
ok, i want to get the facts straight here..... half of the people tell me i cant do this, then the other half tell me not to listen and say i can do it.....
instead of ordering a new facia kit, one installer has told me he can cut out the existing bose system and make enough room for the double dinn.....
whats the go??
https://www.sau.com.au/forums/topic/256938-double-din-install/
find another installer!
The easiest way is to get the correct panel and the correct AC controller and a pocket if you need one. the rest - bracket and top pocket/screen will carry over. if you like I can post images of the rear circuit board that covers the ENTIRE panel to prove otherwise. I will add to that the radio powers that panel.
you can do it yourself. But you just have to be patience with all the panel it needed to be removed. It'll take nearly 2 hours for me to install it myself.
But if you don't have the time then ask an installer to install it for you.
DON'T cut out the existing bose. It'll make it look stupid and your AC controller won't work.
You have no choice to get the Genuine Facia or get the Metra kit from USA, which fit nicer, but crappier AC buttons and cheaper too.
cheers
also - bose or non bose radio. if bose and you do not wist to remove the amplifer then you will also need the leads for that.
when you are ready flick me a PM. I keep most of this on hand.
essentially this is the main part you will need plus the leads and also a/c controller I believe
http://www.japanparts.com/images/ImageFrom...e=1&no=2818
at 11,600 yen from Japanparts.com excluding shipping, including other parts and labour is where the $600-700 comes from.
you paint it. OR you get the correct colour one. I paint mine.
as for your solution.
AC controller,panel, bose interface leads. all up a $900 exercise.
want it - ask.
Hello Guys...
Aeropro I believe sell this facia kit also. Has anyone been able to install the aerpro kit as per below?
I approached Autobarn to see if I can get one ordered in...costs about $500 and I believe it will retain the functionality of the A/C, however I haven't had the chance to get one yet as I am still deciding on what headunit/stereo setup I want.
FP997604.jpgNISSAN SKYLINE V35 350GT 03-04 (Infinity G35)
Replaces Entire Climate Control Panel and retains Full Functionality Of The HVAC System. Metra's patented quick release, snap-in, ISO mount system with a custom trim ring. Recessed DIN opening. Removable oversized storage pocket with built in radio supports. Also includes parts for installation of double-DIN radios or two single-DIN radios Painted to match factory color and texture Custom design allows retention of factory air vents in their original location Comprehensive instruction manual including step by step disassembly and assembly Includes all necessary hardware for a complete installation Contoured and textured to match factory dash
how to get the OEM double din kit? Chris, do u hv stock?
I just got my car.. dont like the audio... Can we connect aftermarket headunit to the original bose speaker and amp? Is what Chris said: "AC controller,panel, bose interface leads. all up a $900 exercise," the option tat i m looking for?
Thanks for this great forum... so much helpful people around~
I do have stock - want?
if so EXACT spec of your car. IE: A/C control,navi,bose?
actually fire me a chassis number. I'll do it that way.
here is it located? i can find vin, engine... but where is chassis?
will ask tomolo and pm u then~ Your $900 including install or??
VIN will do. take a photo of your drivers strut tower. the build plate is there and it will give me all I need.
$900 would cover the bits to make all of this work. you are not in brissy are you? (I travel but only if I haev 3-4 things to do in a city.) cost could well change based on the spec of your car (could be lower.)
I am in melb... *^@#$^&%
Will check the numbers tomolo, and pm u..
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
