pics please. especually if you have pics fitted in the car. postage to melb?
I will put up pics on tuesday as the car is not with me at the moment. i am alittle unsure about postage, i would guess around $50 - $100 mark.
2 door but it may fit in a 4 door as it bolts in just behind the front seats and the rear wheel arch area. ill put pics up on tuesday and you will be able to see.
still able to access the rears?
im guessing u mean the rear seats then yes but i think to have the cage in and seats u might have to mod the seat alittle not sure. i have only had the set in my once and only for a short time and i didnt have the rear seat in.
Hi guys here are the pics. Im going to be away till monday arvo so i probably wont be able to reply but ill go by first in best dressed or best offer which ever the better.
I was unable to have the back of the back seat in while the cage was in the car but with alittle mod to the seat it would work very easy, and look great.
$700 posted anywhere in Aust.
This needs to go. Make me an offer
These sell new for $1500.
I take it this was fitted by drilling holes and fitting plates under the car? Am interested...
  • 2 months later...
  • 3 weeks later...
    • Yep it sure does.   Tone wheel lines up in the same spot perfectly.
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
