From memory thats seems fine on a hot day as my car can get to those temps too. + it depends if you run your A/C or driving up a hill, anything that requires the car to be rev'd alittle harder with effect the temps. Again its normal.
Normal crusing temps are just under 90 degrees.
From my understanding, the R34 GTR's seem to hold quite a consistant temp, even with a bit of a fang.
My friend Tim GTR on SAU has a R34 GTR V-Spec, I took it out for a run, hammered it down the straight and a few corners, then check the MFD with the oil and water temps and they seem stable and yes within that range from about 91 to 98, I think it sat at about 93 degrees C.
What engine oil you using?
motul 300v
So yeah your using the very good oils and fluids which is fine.
Other then the radiator flush (which you have done), the only other thing I can suggest you get check out by your mechanic is your water pump... But should be fine still...
If anyone else can recommend anything, please do.
Overall I think you just pushed it quite hard and the harder you push the car the higher the temps go, again normal.
So nothing to worry about.
How about you take your car out tonight when its a lot cooler, give it a bit of a 'fang' and check the temps again... Atmospharic temps can effect the car too.
it could be one of the 'cold region' GTR's. My 33 was one also (it actually said it in the FAST details), and I needed to change the thermostat and it brought it right down to running normal at between 78 and 82 degrees, on a fang, up to 85 degrees water.
Not sure about the oil at the moment as my apexi gauge is playing up and reading like 120 to 140 at the moment, but when working properly I never saw it over 90ish. The dash gauge sits at roughly 80 to 90 all the time but does move. (I know the Apexi is messing around because it hits 60 straight away upon start up and about 120 within 5 mins of driving where as the dash gauge has just started to move at that point)
Edited by R33GTRKid
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
