The last time I got a bush it was slightly too big for the crank and slightly too small for the gearbox and it ended up pushed inside the crank and its fair mangled. Gonna be fair hard to get out... I'm thinking of leaving it there and hopefully it will stop the next one from going all the way in when I put the gearbox on. Does anyone know what part number or from what car I should get the bush for so this doesn't happen next time?
Thanks for your help
https://www.sau.com.au/forums/topic/257375-which-bush-did-you-use/
I thought all the nissan manual spigot bushes were the same?
IIRC, they are compression fit anyway.. I just went to Nissan and asked for a spigot bush for a skyline and used what they gave me.. maybe get someone to FAST the part and get you a number?
If I get around to re-installing FAST, I'll do it for you :thumbsup:
Should I just leave the worn one in the crank and put a new one in aswell or try to get the old one out somehow?
I'd just slide it out but the insert that its meant to sit in at the end of the crank is smaller than the hole further in the crank so its kinda stuck in there
im having big trouble with this aswelll...
gone threw 3 repco spec spigot bush's.
rb30 crank with a rb25 gearbox..
its just a no go..
once the spigot bush is in the crank it does not let the gearbox output shaft slide threw it..
annoying as f**k.
no idea what to do..
I've used a VL one from the local auto shop as well as an rb25det one from Nissan. They are all the same.
If its binding something is not right with the input shaft or you have not whacked the spigot in all the way.
To remove the old pack the hole full of grease; grab a small socket with a little extension on the end or a piece of metal rod that fits and hammer away. The grease you pack in behind the spigot will force the spigot out as you hammer.
The Red is the current bush that is worn a bit and is stuck further back in the crank, it wont come out because its bigger than the insert that its meant to sit on. The Blue is where I think its meant to go but once you manage to get it into this section its been compressed so much that the input shaft wont fit into it. Is the bush meant to fit in the blue spot or the red spot?
In the red spot it is loose in the crank, in the blue spot its vft.
The only thing I can think of is to leave the old one in as its only going to spin freely on the tip of the input shaft (if the shaft even goes that far into the crank) and machine the outside of the new bush down so it will fit in the crank without compressing.
Let me know if I need to explain further or if you have any suggestions.
Thanks,
Daniel
I have a tool that has a bit that inserts into the bush and i nice shoulder to 'push' the bush with when i hit it with the hammer.
I simply put the bush onto the end of the tool and tap it until it is level with the back of the crank.. i think?
(by memory i think thats what i do.. haha, I dont even think about it when i do it.).
It shouldn't go all the way in. yes it will be tight. but if you get it cock-eyed, then you will have issues.
Also, dont just hammer the end of the bush with the hammer, it will put a nasty bur on it!
Use a socket or brass bar between the hammer and the bush.
does that help?
when getting my last 4 spigot bushs in i have used a wooden end of a broom and a hammer to very lightylly tap it in..
all of them have f**ked up some how..
they compress once in and wont accept the gearbox shaft in them...
My dilemma was similar. Apparently my RB30 originally was attached to an auto trans because it did not have a bushing. It did have a larger one fitted into the crank.
This larger piece inner diameter almost looked like the smaller bushing would press in.
The larger bushing does not fit snug around the input shaft of my RB25 transmission. My thought is to just leave it off and go with the smaller one only. On =premo='s picture, the area above the blue looks like the bush I removed.
Mine must have been an auto because the crank end looks the same as your picture. Today I fixed the problem however.
Step 1, Use small chisel to brake up the bush that was too far inside the crank then use air or finger to remove broken fragments.
Step 2, Use 80p sand paper to round one edge of the new bush to be inserted, then use 400p wet rub to smooth the rounded edge.
Step 3, Make sure the rounded edge will go into the insert opening (may require repeat of step 2, it will still work if it only barely fits).
Step 4, Place thick flat piece of soft wood (I used a cut off of pine) over the exposed end of the bush and hammer until bush is flush with the crank insert.
Step 5, Using a clutch aligning tool (loose input shaft) check to see if the input shaft end will fit inside the bush by hand only. It wont fit because the bush has been compressed into the insert.
Step 6, Using a small round metal file slowly and evenly open up the size of the bush, it is a soft bush and will be very easy to open up so be careful you don't go too far, you may need to unclog your file often with a rag. Repeat step 5 and 6 until the clutch aligning tool end fits inside the bush by hand without force and can spin easily.
Step 7, Continue with engine build.
Edited by =premo=
So I wasted a lot of time Saturday making the bush fit where it isn't meant to go. Dammit, why couldn't someone just tell me it fits back further in the crank. In fact I could have just reused the bush that was already in the crank instead of replacing it.
I always replace the spigot bush everytime the gearbox comes out.. an old one isn't going to break anything but MY GOD the squeeling is horrible when they dry out and catch on the shaft!
Maybe if you'd taken a photo, we could have told you that you had to remove the steel auto bush first ;)
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
