im a bit late to the party
this is the back of mine
ashneel,
you have the xenon headlights yes?
your best bet might be to just buy an aftermarket xenon kit, and chuck it in there, rather than messing around with these wires
wont take much to fix it taco
its just fiddely work with soldering and that
but it can be fixed and probably better using a genuine nissan that the cheaper aftermarket kits
nick
you know me and how much i hate DIY :pirate:
thanks Tharaka. ill give it a go. i dont mind DIY stuff as long as its not a pain. this seems pretty straight forward. pull the lights out solder wires and insulate and bolt it back on. lol sounds ooooo easy. ill give it a go after work today.
also Tharaka if you still havent installed your pod box yet let me know ill come do it for ya
ok so i started on this now. and im stuck lol
iv taken the two bolts off from the top of the lights and the two from the side. the light moves but its holding onto something on the park light side. like there is another bold there.
help please.
Nick youv taken you brothers headlights off before. do you know what it is???
well iv given up on this. i had to drop the side of the front bars cause there was a freaking bolt holding it up so 5 bolts in total holding the headlights.
took the light out had a better look at what wires was left over and ye its a no go. retards cut the wires too shot if i try to solder back the wires ill end up melting the shit out of the housing. so will just get after market HID's.
thanks for all the info though.
if any one is after factory xenons i have a set id be happy to sell.
:ermm:
you most likely have an H1 base plate inserted where the D2R globe would sit. This would need to be removed if you wanted to run a D2R globe.
I'll be running a Kaixen ballast, philipps D2r globes and these harness thingies i got off ebay. So you can effectively return to stock without actually using all stock components.
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
