i think we need some more coloured cars tho............too many white ones lol :(
you forgot me cara lol.mines red does that count haha? im heading out north today so i can probly meet you somewhere and pay and sign the form.msg me today at some point.
  • Replies 354
im so sorry i totally forgot to add u to my list!!!!!!
can you write me a letter explaining what this show is about im going to try and get a permit and the letter may help if not i wont be about to come matty cant tow me
if u come to vilis on friday night ruby ill grab it off of u then.......i have to get someone else form that night so i can get urs too at the same time and ill send them in
Excellent. See you then blow girl :D
blow me hard and fast ruby :down:
When the gear knob just isn't enough anymore :P
:D
Still featuring that big knob at the this car show? ... along with the new doof doof!
Edited by RubyRS4
SAU:SA, disturbing the shit out of you and me since 24/3/2007.
Gutter minds can do that to you.
Only last week I was talking about my erection.
(the house extension erection that is ... mods don't ban me!) :D
Edited by RubyRS4
OK GUYS AND GURLS
we are just over a week away now from the show.............yes not this weekend but the next.......
i will be taking any final entries this friday at vilis..........i will try and be there at about 7-7.30pm
i will have entry forms with me
So far our entrants are the following:
Me - White R34
Troy - White R34
Luke - Silver R34
(now a tentative) Damo - White R34
Vu - White R33
Alex - White R33
Krishy - Silver R33 (yes/no??)
Anthony - Black R32
Carl - Blue R32
Chris - White/Black R32
Dan - Dark Blue R32 GTR
Shane - White R32 GTR
Ruby - Black Stag
I need to know ASAP what the following people are doing
James - Black R33
Krishy
Jack - Red R33
IT IS NOT TOO LATE TO ENTER!!!! IF YOU ARE THINKING OF ENTERING JUST MEET ME AT VILIS THIS FRIDAY NIGHT AND I CAN SORT YOU OUT WITH A ENTRY FORM......I WILL SEND THE FORMS OFF YOU DONT HAVE TO WORRY ABOUT DOING THAT
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
