hey guys,
after doing my exhaust, my next mod is CAI
now i was thinking off getting a pipe coming from the TB all the way to the front bar
so where would i put the AFM, i wouldnt wanna get it wet if i put next to the pod at the front bar.
also where can i get this pipe make up and how much would it cost?
or go this route drift CAI
thanks guys
calvin
https://www.sau.com.au/forums/topic/257546-air-intake/
check in the tutorials section,
I made 2 tuts, one on making a heatsheild, one on making a cai to the heatsheild enclosed area.
I did it on my car, which is now turboed, but still has the N/A GTS4 body, which should be basiclly identical to yours.
cops think its fine, theres a noticeable difference of power when at speed as the cold air rushes to the pod.
I had various ideas/designs but went with the current setup as oppose to something like your suggesting for things like :
less cop attention(hopefully)-which seems to have worked
no worring about idle
actual gains in some power if possible
the overall neatness of the system
gl with it
Adam
https://www.sau.com.au/forums/topic/257546-air-intake/#findComment-4433335
yeah ive always wondered about something like that...seem them for a lot of hondas tho..
Those "long ram" cold air intakes are really popular on NA cars.
The AFM stays in the OEM location, and the pipe design puts the filter in the airflow and routes around the car's bits pieces to get to the AFM. You do run a higher risk of picking up water, since they're inevitably low mounted into the grille.
https://www.sau.com.au/forums/topic/257546-air-intake/#findComment-4434094
