  • Replies 50
+ 1 to the shock and spring combo! i use KYB shocks with whiteline "low" springs. resonably comphy ride but still stiff enough to give a nice feel to the car. altho you wont be able to do that for a few hundred $$ lol...unless you someone manage to find them all 2nd hand maybe.
got told wrong info from someone else :(
fair enough, just to clarify, we have coilovers standard, so they cant be illegal. the illegal part is height adjustment, now what ive been told is that what clarifies as height adjustment is when the height can be altered without adding or subtracting parts from the suspension, although id imagine the interpretation would extend to not being able to adjust the height without pulling them apart.
im going to try and get through with my combo (bilstein/eibach), we'll see how it goes, ill be slipping a non threaded seat on top of the threaded sleeve, this will make it technically legal as u would have to pull the suspension apart and take parts out to adjust the height, even though theres a adjustable sleeve on it, its useless.
imho i dont think 8kg front and 6kg rear are too stiff
i could possibly go a wee bit lower maybe 7-5 you never know
but yeah harsh spring rates could actually casue you to loose grip
8kg and 6kg is probably the highest you want to go on a strret car! i personally reckon that is already a rough ride and my coil overs are progressive spring rates
Damo's right bud. If you speak to suspension gurus like SydneyKid etc, they'll steer you towards 5kg or 6kg fronts and 4kg or 5kg rears with aftermarket adjustable sway bars for track work.
Your tyres are already going to give you a harsh ride due to the profile. Even on the track, the whole idea is to stop the body roll hence the bigger (adjustable) sway bars. The Japs love to put 8 to 12 kg springs on their cars which is fine if you have the glass tracks of Tsukuba etc......problem is, our tracks aren't the best in the world and hitting a slight ripple in the bitumen on a bend or whilst braking at the end of a long straight may see you come unstuck.
I was actually having a similar conversation with Andrew (Blue32) at my place on the weekend where people spend huge money on big dyno numbers to go faster around Malalla yet a properly setup Porsche with alot less power can still embarras some Skylines........even having the biggest brakes on the track would be next to useless if there's no rubber making contact with the black stuff.
EDIT: If you ever get a chance, place a Bilstein shock alongside a well know Jap shock and have a look at the difference in valve bodies.....you'll be surprised at how good the European stuff is.
Another thing that I fail to understand, Bilstein have 9 degrees of adjustment as opposed to some manufactures that offer 16 or even 32......what are you (the average guy) gonna do with 32 settings?.......can you really tell the difference between setting number 23 & 24, LOL?!
ey mate just to let you kno. bring the ADR papers that are posted on a thread here with you to regency. if you read them, nowhere in there does it say that coil overs, adjustable or not, are illegal. Therefore you can leagally have them, ive heard its just a unwritten law at regency that you cant. If they do say something, be polite:D and tell them that no where in the ADR papers does it have that coil overs are illegal, and then just ask for some written legislation somewhere if they persist. My mates have gotten through wid adjustable ones heaps of times. Just make sure the height is legal and you'll be right with the suspension. Just dont hold me to it but defiantely read those ADR papers ive read em a couple of times and cant find anything anywhere
the ADR form in the defected thread leaves a lot of stuff out, which might get u out of a defect from a police officer, but the regency guys know their shit. what i said was what i was told from regency.
ok but out of curiosity ask em for the actual legislation, the actual paper work. because as i said some of my mates have gotten through regency.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
