Dundan/and all,
I need some help re helmets. I don't know which one to get basically but I do know what I want (kind of).
Full face
2 or more intake vents
2 or more exhaust vents (vital)
Removable washable lining (not that necessary but it would be good)
I haven't decided on my budget yet but I don't want to spend $1k that's for sure.
I like the HJC AC-11 found here. The cheekpads are really good and they come in different sizes so you get a perfect fit. I saw an AC-10 at my local bike shop and it was very nice so the 11's must be just that little bit better I guess.
Beyond that I don't know what else to consider. The Arai and Shoei seem too expensive.
Also, I've noticed that the helmets are cheaper in the US. Is it worth importing?
Cheers
https://www.sau.com.au/forums/topic/25767-need-help-choosing-helmet/
Well, personally I just bought a cheap full face helmet from a bike shop - the main criteria was what fit well - its amazing the different fits between brands.
Like Toulia said, it needs to be AS approved for CAMs use.
Of course, I don't know if that's good advice or not, coz despite some big crashes in the race car, I've never hit my head hard...not even in the roll....all I ever do is bounce it off a padded roll cage.
If you're looking at using it for competition or keeping it for along time I strongly suggest you get a nice helmet bag for it - most of the damage on mine has come from when I have been carrying it around, not when I'm wearing it.
You should be ok with importing as long as it has Snell rating, my bell dosent have a asur standard just the snell sticker on the inside, would not be legal on the road but is fine for karting, drags and should be good for cams events.
OK, not sure if you need it for CAMS, but if so, it must meet one of the following:
AS1698 (Aus)
Snell SA90, M90, SA95 (US)
SFI Spec 31.1, 31.2 (US)
SIS 88.24.11 (2) (Sweden)
DS 2124.1 (Danish)
SFS 3653 (Finnish)
ONS/OMK (Germany)
NF S 72 305 (French)
E22 02, 03 or 04 (European)
BS 6658-85 type A and AF/R (British)
I particulary like the "BS" standard :bahaha:
I looked in the Trading Post and the prices were yucky so I went to Cash Converters for a speccy 'cause they are usually exie and they were all under $165. Some were filthy but I got a LAZER that was spotless, fullface and colour matched my track skyline. AS 1698 approved and only $95.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
