Need help. Trying to change my standard BA9S bulbs to led ones (see pic 1). The lights are located in front of the passenger and driver.
I tried to install the lights - a process which takes less than 1 min but there's no lights at all. The bulb is not faulty as i've tried it on my mate's s15, toyota corolla and via a 12V car battery via the + and - polarity. The original BA9S bulb(s) works fine as well when i reinserted them back to the slot (see pic 3)
As you can see from the pics, the installation is pretty straight forward and there's no way you can mix up the polarity. + goes to the bottom tip and - goes to the metal casing.
Any suggestions guys ?
https://www.sau.com.au/forums/topic/257681-passenger-driver-lights-problem/
Hmm . did you buy the LED ones from eBay, cause' im thinking of buying a pair.. but wouldnt want to waste my money if the LED ones dont work.
I know for the middle cabin light, when i bought my LED ones for that, they only worked one way..
Is it the same with your BA9S ?
MRXTCZ
MRXTCZ
Yeah bought it at ebay. Starnge thing is it works in all my mates car but not mine.
The middle light or should i say roof light uses the 31mm festoon light.
Correct on the BA9S, i believe they work on one way as well (polarity)
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
