well im pretty pissed of today as i was reversing out of my garage (how unlucky is this) my garage decided it would be a good idea to just fold and come crashing down right onto of my skyline...as my car was in reverse it kept going so scratching it deeply from the end of the roof (near rear window) all the way til it hit my sunroof which was in a tilted position and that wedged itself into one of the groove of the garage and pretty much ripped out one of the rails...might i add this is an electric roller door, so then i stopped the car jumped out put the garage on manual, and drove my car foward to release it from my sunroof then it just went stright onto my roof and wedged my car inbetween..i was like f**k couldnt move it as it was out of the rails luckily my mate had rang me whom was around the cornor, came over and helped me get my car out, finally did that and the grabbed my neighbour whom is a handyman and he helped fix my garage so now its pretty much ok bit bent but ok...but my car omg the roof is just scratched to shit, im just so cut after you get it running mechanically fine something like that happens pure bad luck so that just tops of the rest of my shitty ass week.....any one have any idea what i would be looking at to get the roof resprayed?
https://www.sau.com.au/forums/topic/257823-fcuking-garage/
oh f**k , my dad had that happen but not to that extreme, he was backing out and sat on the remote to the roller door.
landed on the boot, lucky he had these thick rubber strips on the door, and the door realised there was a car there and went back up.
seen in XXX bodykits window on Cheltenham road Keysborough. '$750 respray any car' .. somthing like that
https://www.sau.com.au/forums/topic/257823-fcuking-garage/#findComment-4435516
damn that sucks man. almost happened to me the day i got my R34. mate sat on the remote and garage started to close car was half way in but trailer was behind me. good thing car was running so had to boot it out.
thats just unlucky though. hope it hasnt taken paint of that it will start to rust.
https://www.sau.com.au/forums/topic/257823-fcuking-garage/#findComment-4435583
at the momet its looks ok...dont think any paint came off..but a couple of deep scratches which are roof length long rest is scrapage....its just i couldnt beleive how it happened, i cant even explain normally my garage would just go back up but didnt do that so i guess it buckeld
https://www.sau.com.au/forums/topic/257823-fcuking-garage/#findComment-4435594
do you have house insurance? a friend had some gear stolen out of his wifes car and the house insurance covered it due to the car being on the property when the stuff was stolen. excess may be cheaper then paying for it outta your own pocket.
https://www.sau.com.au/forums/topic/257823-fcuking-garage/#findComment-4436484
Thats a good call Ron..
Coz just say my car was parked in your driveway and your tree fell on it
you Home insurance would cover it..
https://www.sau.com.au/forums/topic/257823-fcuking-garage/#findComment-4436511
eh dont think house insurance will cover it...cuz my old man said someone reversed into..dunno why, but if i say it came down onto my roof how could i possibly prove it wasnt my fault like i didnt accidently hit the button you know
https://www.sau.com.au/forums/topic/257823-fcuking-garage/#findComment-4437281
^^^^ Doesn't matter dude, your insurance will still cover it, well if your insurance company is a good one it will. Exact same thing happened to a mate of mine in Taylors hill the other week, High wind screwed his garage (panel roller) and he didn't know. Opened door up started to drive out and the thing let go and crashed onto his car! His house insurance covered it.
Can't hurt to call them to see
https://www.sau.com.au/forums/topic/257823-fcuking-garage/#findComment-4437335
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
