got a pair of immaculate Genuine Ganador aero mirrors for an R32
mirrors have carbon finish and have been flow coated (clear)
so they have an awesome shine to them
don't buy ebay rubbish that dont fit properly and are a wiring nightmare
these bolt up perfectly and plug in to the stock wiring harness
due the the shit exchange rate you cant even get a look at these for under $800
Located in sydney and will send anywhere in Australia.
$450ono (including delivery)
https://www.sau.com.au/forums/topic/257909-genuine-ganador-mirrors-r32/
Ohh, very interested. Only is the section that bolts to the door carbon or black? I want to colour code them but if they are all carbon look construction then may as well live with it. Do you have any pictures of the actual units?
No, you can't. and as u can see in the pic, carbon genuine Ganador are not genuine carbon, they're more like film.
i reckon, i of the best looking mirrors on the market!!
as Anth said this mirrors rrp is over $850 these days. so, $450 is cheap
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
