well I put 80kmh because that is supposedly when hicas starts to operate
in high speed mode: it'll initially turn the rears opposite, to improve corner turn-in..
if you imagine the tail is stepping out, so to catch it, a natural reaction is to
catch it with opposite lock, and then that happens .. shades of a losing a rear
engine 911 at speed.
did nissan design for no power-on over steer, making the situation really
difficult to get into so you just resist the urge, and always steer always
where you wanna go?
https://www.sau.com.au/forums/topic/257941-opposite-lock/#findComment-4437772
i took my 32 gtr to wakefield and would have to say that cornering with the hicas in was diabolical on sweeping bends, it was unpredictable and inaccurate, it was like you started off with two wheel steer then all of a sudden the rear would fully engage the 1deg of steering angle which would upset the cars balance and direction, for this reason i have removed it!
https://www.sau.com.au/forums/topic/257941-opposite-lock/#findComment-4438941
Depends whether R32 or R33 and whether 4wd or 2wd. It hasn't been an issue with my R33 gtst - a touch of oppy lock many times around 100kph - no vague feeling - behaved almost like an AE86 or S14 (OK actually a fair bit better than S14)
Edited by simpletool
https://www.sau.com.au/forums/topic/257941-opposite-lock/#findComment-4442609
Absolutely sucks.
Remove the HICAS and you will notice opposite lock at high wheels speeds is much nicer.
I removed mine because I like to get really sideways at skidpan and track days.. it is now a lot more predictable in ALL situations (putting around on the street aswell as beating up on it).
Here's where I finally managed to nail the middle turn but got on it a little too late coming out of the hairpin (carried it a bit wide).. with HICAS it wouldn't have been nearly as much fun :(
https://www.sau.com.au/forums/topic/257941-opposite-lock/#findComment-4442814
I've never had any problem when getting some opposite lock in the GTS4.
The warning I got about HICAS is that if you back off in a corner, HICAS will turn you around. If you keep the power feeding into the rear, you won't have any problems.
https://www.sau.com.au/forums/topic/257941-opposite-lock/#findComment-4446990
Maybe HICAS is a little more suited to the 4wd's, I hated it in my rwd and binned it as soon as I could.
For me, personally, I don't want any part of the car doing it's own thing.. it should only be reacting to my inputs, not what some computer thinks should be going on :D
Edited by bubba
https://www.sau.com.au/forums/topic/257941-opposite-lock/#findComment-4447212
Moneypit, what car do you have?
an r34 vspec ii, and considering whether to hicas lock bar it or leave it as is until I discover what it is like on the track.
"spirited" driving over the alpine pass i didn't have a problem with it, was just wondering if something nasty lurks at 10/10ths.
https://www.sau.com.au/forums/topic/257941-opposite-lock/#findComment-4448798
how much power have you got? are you an experienced track driver, or sort of starting out? what tyres are you using on track? they all make a difference. my advise is try it once with hicas still there. it wont kill you providing you know how to drive within your limits. if you don't like it, then get rid of it. most people that had really bad problems with hicas I would say had hicas that was not working properly and/or worn bushes in the rear end (there are plenty and most of them contribute to a vague feeling rear end). in my 32 GTR when it was working properly it was not a major problem. you get a feel for how to drive it pretty quickly, but it does add sometimes that feeling like the rear is just about to, or is slightly slipping when it's not, but like I said you learn to deal with it pretty quickly. once removed and providing everything else in the rear end is good basically you gain some predictability. if you like going to the track a lot, and end up with more power, and good competition tyres, and better suspension etc then sure, get rid of hicas. if the car is mostly a road car then it's not a big problem. especially if you have a fairly stock car power wise. you shouldn't be getting any power oversteer at 80km/h+ it just doesn't have enough power to do that (unless on purpose). slow speed stuff sure, but not the big stuff.
https://www.sau.com.au/forums/topic/257941-opposite-lock/#findComment-4449855
    • Out of curiosity, how do you cover up the inspection hole? Surely it doesn't sit open like that, right? With grime and dirt coming in and oil going out?
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
