hey i recently bought a 1993 r32 nissan skyline GTS-T with the following modifcations.
Pod filter
Blow off valve
koni adjustables
blitz access ecu (was told either came with the car or was optional when sold new)
i have a few questions.
1. just wanting to know whether there is any information that i need to know about this car or the rb20det engine
2. since i have the blitz access ecu, are they any good?, wat are they like when tuning?, and do many people use/tune them
3.i have noticed lately that when idoling the engine fluctuates around 100 revs, i have placed new sparkplugs and gtr coils due to one dying, would this just be a tune and maybe a dyno that i need?
4. How do i know if the car is running lean?
https://www.sau.com.au/forums/topic/258067-r32-general-discussion/
if your not sure about anything, first thing you should do is take it to a good workshop, with a dyno.. get them to do a FULL service and dyno run. anyone can tell you that theyve had this done and that done... but if you get it done yourself... you will be sure.
most japanese ecus run too rich for aussie fuel.. engine idle could be many things... like a leaking bov, dodgy air flow meter, etc.
keep caroozing this site, and do searchs first before posting a topic asking a simple question.. most topics have already been covered many times.
as for information on the car or the engine... what is it you'd like to know?? the RB20 is the underdog of the RB engines... people dump on it before giving it a chance, but they are capable of being thrashed over and over and handling more power than they have any right to.
the r32 is getting on a bit now, so most of the suspension bushes etc are due to be replaced..
cheers
Linton
1. Nothing especially
2. I've not heard of them. Some guy here reckons that it can only be tuned in the US, and some other guy here reckons they're pre-set and not tuneable.
3. Could be lots of things - try searching
4. Run it on a dyno
yeah cheers guy, i just recently was told by a tuner that the blitz access model are locked and the only real way to tune them is if u have the code (which i dont) or for them to be remapped, not cheap :-(
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
