I NEED THIS GONE ASAP NEED COIN FOR MY HOUSE, BEST OFFER WILL BE TAKEN
its not pretty but it wasnt made to be for a purpose.
92/93 R32 GTS-T TYPE M SKYLINE (UNCOMPLIED) SET UP FOR DRIFT
RB20DET WITH SMALL MODS BUT GREAT RELIABLE RUNNER
14PSI
LARGE FRONT MOUNT
1.5MM SHIMMED DIFF (LIKE A LOCKA)
GREAT 5 SPD WITH HEAVY DUTY CLUTCH
TEIN COIL OVERS
THERMO FAN ON SWITCH IN CABIN
AUTOMETER MONSTA TACHO,BOOST GUAGE,DILDO SHIFT KNOB
STRIPPED TRIM TO 1 SEAT AND DASH ONLY (HAVE MOST OF TRIM IN SHED THOUGH)
MATT BLACK OUT SIDE SPRAY STRAIGHT BODY PAINT OK.(dirty in pics)
FULL KIT, B AND N SPORT REAR BAR AND VERTEX REAR BAR MINT,GTR REP FRONT BAR AND SIDE SKIRTS
GTR FUEL PUMP,UPGRADED INJECTORS,REMAPPED ECU
BOOST T
COLD AIR INTAKE TO TURBO THRU HEADLIGHT POSITION
6X GTST STOCK WHEELS WITH GOOD RUBBER
LARGE TYPE M BRAKES
MECH A1
FULL JAP BRAND EXHAUST FROM TURBO BACK (3") WITH TWIN DRIFT TIPS
HEAPS MORE I CANT THINK OF ATM.
THIS CAR IS A GREAT RELIABLE DRIFT CAR SLIDES WITH EASE AND GOES REAL WELL WOULD GUESS ROUND 170RWKW'S BUT WEIGHTS f**k ALL.
CALL 0402217466/PM
CHEERS TYSON
ONLY SWAPS IM INTERESTED IN IS FOR A REGISTERED DAILY AND CASH PREFER COMMOS.
IF U HAVE NO MONEY OR CANT GET MONEY WITHIN 2 DAYS DONT MAKE AN OFFER HAD WAY TO MANY TIME WAISTERS AS IT IS.CHEERS
https://www.sau.com.au/forums/topic/258144-r32-drift-car-for-sale/
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
    • The fact that US/JDM plates actually fit the skyline bumpers properly is a big, big thing for me as they are the correct dimensions. Annoyingly you can't opt for a normal plate (or plate combination) in that size. You have to make up your own one, and at that point you'd still know it wasn't randomly assigned.
    • Well, really, that's any ECU, because it's not so much the ECU that the tuner connects to, but a laptop that's connected to the ECU. You have to have the tuning software installed locally. The "remote" part is essentially just remote desktop (RDP) or VNC type access. Nevertheless, if you're looking to upgrade, then you're immediately in the Haltech/Link territory, both of which can be done by any number of competent tuners here in Oz. But without a dyno, you'll definitely also need a wideband O2 sensor fitted, and you'll probably be relying on "auto" tuning a bit, where you drive it around under various loads and then apply the corrections that the ECU learns (basically applying the fuel trims that the ECU has to do to correct the mixtures). Tuning the timing is a little harder. It can be difficult to trust the old OEM knock sensors on RBs, so it is definitely best to have someone who knows what they're listening for, with knock ears (a piezo microphone connected to the engine, and and little amp and headphones so the listener can hear the angry men with hammers who live in the engine). That is more difficult to do remotely, and I suspect the only sane way is to be quite conservative on timing. But that's OK. You're probably waaaaay better off with conservative timing where you are. What is the fuel situation? 98RON available? Or low grade jungle juice?
    • I see your point, I didn't think too deep into it, was purely focused on the price. There's no bad blood between myself and GSM, they acknowledged the price was cheaper else where and at the time couldn't match it.
