i thought it suited :(
i wanted to see skylines actually enter rather then just cruising ell wel
well unfortunately my gearbox was making some bearing type noise 1 week prior to the event so that screwed me over, wasnt able to attend.
i wouldve loved to show most the v8 turnout what skylines can do :D.
ahhh well theres next year for me, with much bigger setup ;)
went yesterday wasnt a bad day, but no1 knew what they were doing in the stampede event. apart from that 180sx that was going sideways up the straight.
  • Replies 82
i wouldve loved to show most the v8 turnout what skylines can do :(.
ahhh well theres next year for me, with much bigger setup :D
Was it this 180?
Edited by W0rp3D
i ended up entering was good fun just spent most of the time drfitng during the cruising and kept getting told off for being an import lol, would have liked to see more skylines enter
This would be you then?
Firstly - to the guy with the S2 33 - nice car..
I think the reason why skyline or other import drivers stay away is the sheer stupidity of the v8 meathead crowd. Sure there are some nice 8's that go, no doubt. But there are the fair share of crappers that go aswell. But cos they have a v8 and set of straight pipes the moronic crowd thinks they are gods.
The other reason I think it's not worth entering is that cruising is a joke. I found it funny that on the TV add for the Easternats it said to avoid the traffic and stay home this easter - go to the easternats. If anyone else here has been an entrant you'll know exactly how much of a joke cruising is and how stupid saying that in their tv add was.
For those that havent - heres a rundown
you go flat out down the straight to the first corner, slow to 5 k's cos the traffic is banked up infront of you, crawl through the next few corners to the nack straight, flat out for 10 secs then back to a crawl. A lap at "cruising" speeds takes 8-10 minutes.
You could probably get around faster on a pushbike... although the officials would still tell ya off if you popped a mono down the back straight...
Burnouts, well watching them it's easy to spot the guys that go to shows and do a lot of burnouts and the ones that just practise in the kmart carpark.
And finally, if you have ever had to deal with Jon Davison and getting "different" cars entered, scutineered, you'll know he knows as much about his own event as britney spears does about singing.
but thats just my 2c...
that mighty boy was mad. Had a huge day out, was nice to see a few skylines out there..the perfect day for it on monday..but my head hurts bad and I have to work today...so feel fantastic...lol
omg at the amount of shit the guys on the PA were giving skylines everytime they came up LOL. they really dont like the rice burners lol.
yeah i saw manni there in his r33gtst a r32gtr, the white r33 gtr from sau, and a silver r33gtst.
did anyone see that 180sx? the japarehouse one who was just drifting the track? lol
Yeah f**k'em, although I did not goto Easternats I see where you are coming from.
Guess it's the same when you see a Commie at a Drift Event but I'm not sure if the guys at the PA give them shit..?
Anyone see a white Nissan 180SX with a HKS POWERS sticker across the windscreen?
"Boof" is his name, met him a few times and that's his 180SX with a high mount turbo + all the goodies under the hood.
couldnt have said it better myself!
the amount of times i had people say to me this weekend "why dont you put your car in?" and the amount of times i told them "sorry, but burnouts arent my cup o tea!"
i was only too happy to stay well away from yob fest 2009! i like my car the way it is... NOT BENT OR IMPOUNDED!!! :D
sorry if i got a bit carried away...
That was your first mistake, you listened to the tossers.
You mean the one i posted pics of a few posts back?
yeah the commentators are fagets they didnt even know half the time what skyline it was once even called a r32 a r31. that 180 was crazy he even made the stupid crowd get up and applaud a lil sr20 made more smoke then all there v8s lol
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
