  • Replies 138
u guys r funny as...jazz drivers r cool ;) but i must say my jazz would b the coolest hhaha should see it :blink:
Update on the car:
I got a few nice jap parts going on tomoz i think or maybe thurs. Decided to give the blitz BOV valve a miss going ahead with the Blitz pod filter, getting boost controller and gauge, greddy turbo timer, a front pipe so ill have a full 3" system in the car now. And the bigger turbo is being organised to b installed( cheers to matt) :) . Also needs a new windscreen and speedo which is also going on this week. Gonna dump it this week 2 hopefully.
Edited by juzz
Welcome Juzz, nice ride...I hope you intend to toss the Daewoo front end and put a GTR bonnet, grill and bar on..Mmm sexxx
Shame your thread has deteriorated into another cock smoking contest.
Spot the whale?
Update on the car:
SMART Move!
Is your Honda Jazz (Honda Fit = JDM) as cool as these?
welcome juzz,
theres a few people going up to DECA to spectate this weekend..you should consider going down and checking it all out
heyyy yeh im gonna join 4 sure. Yeah pretty sure ill come check it out this weekend.
Funnky lil Jazz you got there!
Looks nice.
why thankyou he isnt so bad :). Sounds system kick ass in it gotta swap it into the 32 this week lol. Jazz is getting stripped of his assets haha.
evade: yeah i know lol but the car rly needs to be serviced etc. so probs not the best idea to take it track this weekend. Once the bigger turbo goes on and it has a good tune and new ecu ill b alll ready oh and my adjus. coilovers :(
those Honda Jazz/Fits are awesome in Jap spec.
I saw one on Toorak Rd and it was white, lowered with some rays light weight wheels and a nice sounding exhaust :(
mine sounds nice haha its not stock....has k&n pod filter, full high flow catback exhaust and x force extractors and lowered with kings. It actually doesnt go that badly. Vtec too.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
