I have no interest in getting a rear strut brace, as I use the wagon rear so often with bikes and surf board and shit. And yes i am aware how easy it can be removed as i helped cheff_stagea install his.
how much are you after for the wing mike? Its not the KR4 color is it?
$150 for the wing, it's not the standard kr4 colour though
on a side note, is that you i spotted last night east side of town with adams wheels? car looks good now it's been dropped :thumbsup:
how hard are the wings to fit mike? Can i get someone to spray in and fit it myself?
Yeah that would have been me unless someone else is getting around in a silver stag with gold'hearts. Purchased the wheels of adam a while ago now :)
Didnt end up dropping it :'( One of the collars on one of the coilovers wouldnt budge no matter how hard we tried! CRY!
Hey Mike.
I don't suppose I could get you to give us a little description on what type of bar you have and how you installed it please?
I agree with the others. It looks really neat. And easy to remove.
dont worry nick, we will get him. PS their is your evil twin up her in Mt Barker
does it have a ding as well?? :)
really? it looked alot lower than the last pics i saw of it :/
What are you saying Mike? Chris has put on weight??
  • 4 weeks later...
Well looks like ill be putting in an SITC and then a front/dump to complete my zhorst. 3inch to hi-flow cat 3, 1/4 cat back.
Will then get SAFC II retuend and SITC tuned at bostwerx. Profec B ill do my self :P
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
