Hey Guys
Just had my r32 gtr dynoed
R.I.P.S rb 30 billit main cap block
stock crank
argo rods
custom je pistons
rb26 head by rams
hypertune plenum
twin hks 3037s turbos
Car made 553.5kw at 4 wheels on shell 98 pump fuel
24psi boost it feels insane on the street makes full boost by 5000rpm
and pulls till rev limit 9000rpm
We still have nitrous and race fuel to play with so we will see how we go.
https://www.sau.com.au/forums/topic/258259-5535kw-at-4-wheels-pump-fuel/
  • Replies 165
Man that thing looks the ducks nutts! Great power and response for a set of 3037's to be making full boost of 24psi by 5000rpm, gotta love the advantages of the good ol ' fork lift ' rb30's over the 26 bottom ends. Got some more pics of the completed motor and car?
Cheers, Mat.
Haha nice work :thumbsup: If I remember rightly thats more power than a few of the 9s GTRs in Oz are running, just on 98 octane pump gas? Get some E85 and more revs (the dyno plot implies there is more useable power band to be had) and boost and some MT drag radials on that sucker and I can imagine some pump gas/street tyre records falling!
awesome work...good luck with it...another Silver Monster will be lurking out at WSID.
glad i did the upgrade now with all these tough cars coming out of the woodwork.
the tune looks to be still fairly fat...but at that boost on pump it needs to be...and why didn't they run it in shoot-out mode?
i have a question, i do not want this to be taken the wrong way at all. Yes its a very tough example of a gtr.
How would this thing drive ? say on a track ? or on the street, if your only over 350kw for 30 - 35km's in th rev range would it render the power useless and thus make the car really slow?
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
