Back from a coupla years drinking the Pom's beer & shagging their women (well, trying to) I was wondering if you lot still hit the City arrie or the Great Northern for monthly pi55ups. Word on the street is that beers are fairly awesome.
Also if anyone is selling a cheap R31 manual, that may also tickle me fancy...
https://www.sau.com.au/forums/topic/258319-wheres-the-beer/
Cripes, who let you back in the country? :D
https://www.sau.com.au/forums/topic/258319-wheres-the-beer/#findComment-4447117
Wasn't so much I was let back in 'straya...
Was rather more the UK suggesting I should leave. Not really sure why :)
Who organising some drinking then? It be Thursday so I'm off the Erko for $9 juggage
Bring on a a pizza cruise, where is mars (STR33T) when you need him
https://www.sau.com.au/forums/topic/258319-wheres-the-beer/#findComment-4449232
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
