Afternoon all,
I recently purchased a NISMO polished gear knob through an auction site and wondered if there was any way to tell if its authentic?
It comes complete in the plastic box, printed cardboard etc though I seriously suspect it's a fake for a few reasons and wondered whether anyone had heard of these being produced on the counterfeit market?
If anyone has one of these can you pm me please? http://www.nengun.com/nismo/aluminium-shift-knob
Things that dont look right, the finish doesnt look perfect at all, with small like blotching in the shine coating. The letters where it says NISMO up the side also have this blotchy type finish, it's certainly far from perfect and the sticker you get is only the 6 speed and is square and doesnt have any resin coat or anything, just a plain sticker that if fixed would hang over the edges. Looks well dodgy.
https://www.sau.com.au/forums/topic/258614-fake-nismo-gear-knobs/
Mmm, haven't heard of fake ones before but I know that the sticker for the normal, non GT type knobs looks pretty cheapo. They're meant for sticking onto the actual interior and not on the knob... there is a specific model which comes with a little coin like piece which has a shift knob pattern in it (both 5 and 6) but that's not the model you have.
Anyway, it it looks blemished, perhaps the guy kept the box and used it for a bit and tried to fob it off to you?
hmm i got a nismo polished gear knob as well purchased on ebay with nismo clear side indicators.
after a couple of months its starting to go pink on one side? mayb its fake?
but now i've replaced it with a bubble gearknob so its ok
Yeah I'm a little suspect on this. I wont name anyone here, I've messaged the seller and will wait to see what he has to say to the comments I passed through. I'll try and find somewhere in Brisbane too that stock these and compare them side by side.
Afternoon all,
well how much did you pay in comparison to market price?
cause 9 times out of 10.....if the price is too good to be true....then its most likely NOT......
im guessing you didnt buy it from Nengun right?
they are very reputable and do offer genuine products
Yeah my titanium shifter was like $180!!!! But exellent quality.
And if yours is going pink Takz, that would be the chrome plate wearing off. What your seeing is the copper plate under the chrome.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
