hey there,
just taken out my NGK BKR7E that have been gapped to.5, my mechanic has ordred me bosch plugs to replace them. what should i gap them too?
RB26 about 500hp, 18lbs boost, read that the bosch plugs arent that good?
cheers robbie
https://www.sau.com.au/forums/topic/258766-spark-plugs/
hey there,
cheers robbie
NGK all the way, i use r5671A-8 which is a not protruded plug.My rb20 makes 299rwkw on 1.5bar(20lbs)i keep the gap they come out of the box .8mm an no problems. Ialso used the same plugs in my hk ute with a blown 400 sbc an that made 727rwhp.On the part number for the plugs r5671a-8 the -8 is the heat range
https://www.sau.com.au/forums/topic/258766-spark-plugs/#findComment-4448439
Don't get bosch.. they are not good spark plugs for the RB26.
i have NGK BCPR7ES which come standard set to 0.8. leave them at that and the car will run great.
Edited by SuperElectric
https://www.sau.com.au/forums/topic/258766-spark-plugs/#findComment-4449272
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
