Hey guys,
Got a Motokhana on Sunday and decided i should fix my handbrake.
When i do like 70km/hr and pull the handbrake nothing really happens. The car slows down alittle but the rears dont lock. Iv'e tried adjusting the nut near the handbrake and that doesnt fix it at all.
Iv'e taken the rotors off and see two screws but they dont look like they do anything.
Any idea's? New handbrake shoes?
Thanks Luke
https://www.sau.com.au/forums/topic/258781-handbrake/
i had a similar problem, whats happening is your shoes are slightly in contact with the hub... which is normal.. but your cable is so tight that your just pulling them on harder instead of them grabbing... heres how you fix it.
take off your rear wheels.. you will see a rubber grommet on each disc.
remove the grommet, move the hole to the bottom and look in with a torch... you'll see a gear type thing. move it with a screwdriver locking up the brakes completly, then back it off until you can start to move the disc by hand (bout 3 clicks), then back it off another 2 clicks. your handbrake at the back is now properly adjusted, so its all up to the cable now
adjust your cable at the hand brake so you only have a bit of movement in it before it actually engages.
a tight cable will hold the shoes against the hub slightly, when you go to pull the brake, your just pulling the shoes on harder... they dont have that sudden grab that locks the wheels.. so if the shoes are adjusted properly at the back, they will have a bit of clearance, and with the cable adjusted with a bit of slack.. your handbrake should lock with very little effort.
cheers
Linton
https://www.sau.com.au/forums/topic/258781-handbrake/#findComment-4448504
cheers
Linton
This worked!!!! Thank you so much mate. :glare:
https://www.sau.com.au/forums/topic/258781-handbrake/#findComment-4450460
no worries... and as for the shoes... ive been in the game for 7 years now... except for drum brakes... ive never replaced a set of handbrake shoes.. and an r34... a highly doubt you will be replacing the shoes in your life of the car.
https://www.sau.com.au/forums/topic/258781-handbrake/#findComment-4451670
This man, he knows...
Hand brake shoes don't really "wear out" unless you're one of those gumbys who drives around with the hand brake still partially on...
Most of the time, when you pull the hand brake on, the car is already stopped, so there isn't really any "wear"
Edited by MBS206
https://www.sau.com.au/forums/topic/258781-handbrake/#findComment-4451987
I have no idea if my car has a LSD, i jacked one side up and i could turn the hub fine and make adjustments. As for the "worm screw" to make the shoes tighter or looser, screw it up for tighter and down for looser....also if you see an actual flathead screw in there, leave it alone, trust me.
https://www.sau.com.au/forums/topic/258781-handbrake/#findComment-4458282
I have done this adjustment, but must have not backed off enough, I think 5-6 clicks from shoes locking the hub. Anyway, the shoes must be naturaly rubbing to much as the hub and wheel heated up fairly hot. I could move the hub easily enough once adjusted, but you could hear the shoes move with the hub a little till they hit the shoe stop pin. Just thought I'd mention it so peeps could be aware this can happen. Or maybe I just didn't put the brakes back together properly. :D
https://www.sau.com.au/forums/topic/258781-handbrake/#findComment-4458784
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
