I have one of those timing lights that shows up double what it really is. ie, 30 degrees when it's really 15. How would I go about setting it to anything higher than that? 30 is the highest marking on the crank.
  • Replies 126
Thanks SydneyKid - that's exactly what info I was after. I'll be having a play with the timing next Wed when the car is having a play on the dyno.
Lukits01 - turning the CAS anti-clockwise will advance the timing. Is this right everyone? Or have I stuffed up the direction again... LOL
cannot really add much to what has already been said, but.........
The easy way to turn the engine over to exact TDC, or anywhere else, is to put it into fifth gear and roll the whole car backwards or forwards. Slop in the drivetrain allows you to bounce the engine. Try it, you will see what I mean. When it's there, put on the handbrake. Easy. If you have an auto, bad luck.
Another thing, fair enough you can retard it four degrees, but how do you know that the starting position was correct ? Also belt tension and belt stretch just by itself can shift it nearly that far.
Think about it, if the belt has stretched, and you tension in the belt a bit on the slack side, both cams retard by however much the belt has stretched. only a couple of mm is actually a fair way. One whole turn being 720 degrees.
To do it properly you need a dial indicator and degree wheel, and find out exactly where each cam is, and where it should be. It's a lot of work, and a pain in the arse, but its the only way to know for sure.
Hi Warpspeed I am confused, the standard RB pulleys have marks which you line up for TDC of the camshafts. The crank also has a mark on the pulley for TDC. If these three marks all line up then the crank is at TDC, the inlet camshaft is at TDC and the exhaust camshaft is also at TDC. If the adjustable pulley is marked correctly then you can lock the camshafts at TDC and the adjustable pulleys should just slip on, when they are on zero correction. If the adjustable pulleys have marks for degrees and they are accurate, then you know the exhaust camshaft is 4 degrees retarded when it is on the 4 degree mark. No guesswork required.
Back in the old days we use to have to degree in a camshaft because the grinding was not as precise as it is now. I haven't found a camshaft in a Japanese DOHC multi valve engine that is not marked precisely for TDC for the last 10 years or so. Since we tune the camshaft position on the dyno it doesn't matter anyway, we adjust the pulleys to the point that makes the power curve the way we want it. So I don't care whether it is 4 degrees or 10 degrees on the pulley marks, it is where I want it that's all that matters.
Hope that helps
Yes I agree, the cams themselves are pretty precise, and probably so are the gears and crank key. The problem is only with the belt.
If the belt is slightly longer on the tight side because it has stretched, and you take up the slack with the adjuster, then both cam pulleys will have rotated very slightly anticlockwise with respect to the crank. As far as the timing marks go, you can only really fit the belt one whole tooth out, and the error is pretty obvious. But what if it is just a fraction of a tooth out ? The timing marks will still look o/k. Would you actually notice 2mm ?
Not sure, but I think the cam pulleys have 48 teeth. that is 720/48= 15 degrees per tooth. 2mm of belt stretch (with an 8mm pitch belt) is one quarter tooth, or 3.75 degrees.
2mm belt stretch is not a lot between crank and exhaust cam over almost half the whole belt length, on a high mileage belt. Sure, the belt will be a bit loose, but tightening it back up could shift both cams by nearly 4 degrees.
If you really heave on the adjuster, you can actually see the damned things move ! I kid you not.
I am probably being a bit of an old woman about this, but people here are going to a fair bit of trouble and expense to do the 4 degree exhaust cam tweak, expecting to pick up measurable power. If the cams are maybe four (?) degrees out to begin with, the results may not always be quite as expected.
  • 1 month later...
Hey guys
my cam gears are finally here and Im about to try and install them, probably this weekend
been looking at the engine bay
was wondering how do you take off the Cam gear covers off?
how many bolts are there and roughly where are they located?
hahah i lost one nut from the cam cover belt. It just disappered :) And the worst thing was that it was the last nut i was puttin back on. Then trying to find the thing took longer then what it took to install the cam gear. It was really easy, thanks to all the help from everyone. Its gettin tuned tomorrow.
thanks guys cam gears installed and working
awesome stuff
hit full boost by 1000 RPM ahhaha
just a note there are actually 8 bolts on the cam cover
hey when setting the base timing to 15 Deg is it on the 3rd white line after the first orange line? and what RPM should the timing be done at?
My Trust Ex Cam Gear arrived yesterday from Nengun (13,000yen + Shipping, took 2 business days to arrive). I just re-read over this entire thread to see if i'd be able to do it myself and it was an absolutely comedy haha.
I was going to ring UniGroup this arvo and ask them to do it (I want a before/after Dyno run) but $160 is pretty rich, i'd happily pay $100 for it if its only a 30min job but $160 makes a cheap mod into an expensive mod.
Hey JimX... :bananaman
Hi JAY95R33/ JIMX,
Did retarding the ex timing make the car feel any different?
Do you mean "did retarding the exhaust cam gear make......."
Then yes, as said earlier on in this thread, I found retarding the exhuast cam gear by 1.5 degrees (3 degrees crank angle) gave me an improved mid range.
Cheers
Jayson
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
