Hi, firstly can i say congrats to administrators for giving people like me access to such a great resouce such as this forum.
righto to the problem.
The rb26 in my r32 gtr has developed a knocking noise starting at 2200-2400RPM and increases in noise intensity to 3000RPM.
At idle the engine there is no miss, no noise showing no sign of a fault.
I have changed oil, pulled out the cams, compressed each valve individually and put it all back together to eliminate any issues with cam timing however the noise is still there.
The noise was first noticed after doing several 1/4 mile runs on the g-tec. I had a wideband installed during the runs to ensure mixtures were ok as the engine had been rebuilt about 2000km's before (by myself). The turbo's were running standard boost. There was no noticable noise to indicate a failure, the noise was only noticed when i left to go home.
the noise is a solid noise at 3000 almost sounds like it is in the inlet side of the head.
I havent yet changed the cam timing to ensure it is not valve knock. The engine turns over by hand fine with no noticable issues. On inspection of the cams there was no noticible sign of an issue, aside from a wear mark on no 6 exhaust base circle but checked clearances and was fine.
i have heard big end knock before (the reason for the rebuild) and i dont believe it is the issue.
The list of mods for stage one
- JE forged pistons,
- ARGO rods with arp bolts,
- Jun oil pump,
- Calico coated main and big end bearings,
- Tomeii cams type B and valve springs,
- Tomeii head and manifold gasket set,
- Aftermarket split dumps,
- Garrett GT2560 turb's
- new r33 crank
- head oil restrictor
- tomeii sump baffle
- modded oil return line to sump
- turbo blankets and manifolds heat wraped
- Ross Harmonic balancer
- ARP head and mains studs and bolts
if anyone has come across this issue before and knows what it may be can you please enlighten me as it has me puzzled mostly due to the inconsistancy of starting at 2200 ie a valve knock would be heard at idle, so too would a big end failure. I am maybe thinking it might be an issue with a peice of ancillary equipement on the engine - not explored.
thankyou for any future help.
https://www.sau.com.au/forums/topic/259147-rb26-engine-noise-help/
I have an R32 GTR which had a knock about two years ago, at 2000--3500 RPM It sounded pretty bad but hard to believe, turned out to be only the cam belt bearings. Just a thought.
Thanks, when you say cam belt bearings, do you mean the cam belt tensioners, i never thought of them being an issue because they are new, but doesnt mean they havent failed i will check it out thanks.
Blown gasket.
Mine did that last week, the sound was a strange one and sounded like a few other things that have gone bang on my gtr over time, but as soon as it was looked at by the shop they saw the carbon buildup around the front turbo manifold and then it became clear. I couldnt see it cause it happened at night
Its probably not, but doesnt hurt to check and rule out that possibility :D
Blown gasket.
thanks its on the list of things to do :(
possibly dropped a valve guide?!?
its a really common problem with rb26 and i see in your mod list they have not been replaced...
yeah your right i think a head pull is the next step :) i was trying to avoid it (hence the post and if anything else might be the prob) but have pulled it down as far as having cams out and didnt find anything that was likely to be the issue but because it was so over a year ago that it happened i put it back together to relearn the noise etc, and also rule out some of the simple things.
thanks for the advice :P
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
